graemevw 823 Posted March 30, 2020 3 minutes ago, rwordenjr said: I believe the reverse knuckles was for the original. I have a rere just like you’re getting and mine is built normally and it doesn’t have the steering issue the original had. Ok, thats good to know. Ill check it out when i get it. Share this post Link to post Share on other sites
graemevw 823 Posted March 30, 2020 25 minutes ago, Hobgoblin said: They are screw pins. Shims are a good idea, plus I've found that top force CVD seem to fit too if that's your jam. I hate screw pins! Looks like id better order some 3mm stainless rod then. Share this post Link to post Share on other sites
Hobgoblin 1059 Posted March 30, 2020 Good shout. However I will take those nasty screw pins of your hands should you find yourself unable to bear looking at them Share this post Link to post Share on other sites
graemevw 823 Posted March 30, 2020 25 minutes ago, Hobgoblin said: Good shout. However I will take those nasty screw pins of your hands should you find yourself unable to bear looking at them Ill give you a shout once they are surplus. Ive got quite a few of them kicking around now, i swap them out whenever possible although not much i own uses them. Share this post Link to post Share on other sites
