glob356 36 Posted April 26, 2020 Hi rwordenjr, I have some trouble with my original one too. I ordered Tamiya #51000. It's a strong one. Take care. Glob356 Share this post Link to post Share on other sites
rwordenjr 858 Posted April 26, 2020 27 minutes ago, glob356 said: Hi rwordenjr, I have some trouble with my original one too. I ordered Tamiya #51000. It's a strong one. Take care. Glob356 Thanks man! I’m still waiting on the dt02 turnbuckle set to arrive so I can install that and the dt02/3 c hubs. Will post back here when I’ve got it set up. Here’s the proline dirt hawgs I put on the car today. 2 Share this post Link to post Share on other sites
glob356 36 Posted April 26, 2020 10 hours ago, rwordenjr said: Thanks man! I’m still waiting on the dt02 turnbuckle set to arrive so I can install that and the dt02/3 c hubs. Will post back here when I’ve got it set up. Here’s the proline dirt hawgs I put on the car today. Really nice looking car! Share this post Link to post Share on other sites
glob356 36 Posted April 26, 2020 1 hour ago, glob356 said: Really nice looking car! @rwordenjr could you please give the exact reference of the tires. Tks. Share this post Link to post Share on other sites
rwordenjr 858 Posted April 26, 2020 2 hours ago, glob356 said: @rwordenjr could you please give the exact reference of the tires. Tks. Proline dirt hawgs 1071-00 Share this post Link to post Share on other sites
rwordenjr 858 Posted May 2, 2020 On 4/26/2020 at 5:42 AM, glob356 said: @rwordenjr could you please give the exact reference of the tires. Tks. You happen to know if the stadium blitzer body is a direct fit to the stadium thunder? No different body mounts or anything like that? Share this post Link to post Share on other sites
glob356 36 Posted May 4, 2020 On 5/1/2020 at 9:59 PM, rwordenjr said: You happen to know if the stadium blitzer body is a direct fit to the stadium thunder? No different body mounts or anything like that? Hi @rwordenjr, Please check the photo of the Stadium front. For the rear, it's custom due to the shock mount. Share this post Link to post Share on other sites
rwordenjr 858 Posted June 20, 2020 On 4/15/2020 at 6:55 PM, glob356 said: Hi @rwordenjr, Could you post a picture of your modification? Tks. Glob356 Took a while but here you go. DT02 turnbuckle set mounted on Stadium Thunder with aluminum DT02/3 C Hubs to replace the crack prone plastic Stadium Thunder ones. Added 1 2.5 mm spacer on each side of C Hub to reduce slop. Thanks @Jonathon Gillham for the link to the spacers ! 1 Share this post Link to post Share on other sites
Jonathon Gillham 3171 Posted June 20, 2020 9 minutes ago, rwordenjr said: Took a while but here you go. DT02 turnbuckle set mounted on Stadium Thunder with aluminum DT02/3 C Hubs to replace the crack prone plastic Stadium Thunder ones. Added 1 2.5 mm spacer on each side of C Hub to reduce slop. Thanks @Jonathon Gillham for the link to the spacers ! Are they the alloy spacers from Banggood? Or did you find them on the parts tree? Share this post Link to post Share on other sites
rwordenjr 858 Posted June 20, 2020 18 minutes ago, Jonathon Gillham said: Are they the alloy spacers from Banggood? Or did you find them on the parts tree? The alloy ones from banggood 1 Share this post Link to post Share on other sites
