Dandy 5 Posted April 17, 2020 Hi all, Just bought a used Amarok with the CC01 chassie and need better tires asap. Is there any 1,55 tires that fit the stock wheels or do I need to buy both new tires and rims? If so which ones do you recommend for the Amarok? Share this post Link to post Share on other sites
Bash 356 Posted April 17, 2020 The CC-01 uses 1.9 wheels stock. While limited, there are some options for 1.9 tires that will fit the smaller proportions of the CC-01. You will have to change wheels and tires for a 1.55 setup. I've attached a spreadsheet of commonly used tires in the RC crawler world that you can filter by wheel size and tire hight. Anything under 4" (102mm) tall should clear under a stock CC-01. https://docs.google.com/spreadsheets/d/12BVRbkra0vsKbtJ2unyEdAQIqClM7O-5SqB9tApNi2o/edit?usp=sharing 1 Share this post Link to post Share on other sites
Supercoolnothing 721 Posted April 17, 2020 I use 96mm absima steelhammer tyres on my cc-01 with every other row of lugs removed so they flex more and have more grab going over obstacles. They come pre-mounted so all you need to do is swap em out and be amazed at the difference over the stock tyres. They're pretty cheap at about £17 for a pair but if you can track down a couple of pairs of fastrax kongs they're exactly the same tyre but slightly cheaper. (I only found that out after I'd bought them.) Share this post Link to post Share on other sites
Dandy 5 Posted April 27, 2020 Thanks for the replies. Just ordered a set of RC4WD Mickey Thompson 1.55 Baja MTZ Scale Tires. OD on these is around 85mm which I think is a reasonalby upgrade in size compared to the stock 78mm tires. Really want to keep the scale look as much as possible Share this post Link to post Share on other sites
Otis311 196 Posted April 27, 2020 What are you using for wheels? Will the 1.55 fit the stock wheels? For 1.9 tires I would go with RC4WD Rock Creepers or Mudslingers. They have a small diameter that fits a CC01 reasonably well. Share this post Link to post Share on other sites
Dandy 5 Posted April 28, 2020 I will be using the stock wheels. Hopefully it should not be any problems stretching the 1,55 tires onto these. I will keep you updated Share this post Link to post Share on other sites
Busdriver 6209 Posted April 28, 2020 I wish you luck. I have some 1.55 mickey Thompson tyres and there’s no way they would stretch that far. Also it would alter there ratio rather a lot and reduce sidewall strength. Share this post Link to post Share on other sites
Dandy 5 Posted April 29, 2020 I will give it a try and if it doesn`t work I just buy some 1.55" wheels Share this post Link to post Share on other sites
Aerobert 2143 Posted April 30, 2020 (edited) If it not work you can also have a look at the MST KM tires. 90 mm outer diameter, direct fit on 1.9 wheels and pretty capable off road, in my opinion. Part number is 831005 for medium and 831006 for the soft ones. Edited August 30, 2021 by Aerobert Compressed picture Share this post Link to post Share on other sites
Dandy 5 Posted May 1, 2020 On 4/28/2020 at 12:36 PM, Busdriver said: I wish you luck. I have some 1.55 mickey Thompson tyres and there’s no way they would stretch that far. Also it would alter there ratio rather a lot and reduce sidewall strength. Well to fit the 1,55 tires was a piece of cake so how you could not do this is a mystery to me :) Share this post Link to post Share on other sites
Dandy 5 Posted May 1, 2020 14 hours ago, Aerobert said: If it not work you can also have a look at the MST KM tires. 90 mm outer diameter, direct fit on 1.9 wheels and pretty capable off road, in my opinion. Part number is 831005 for medium and 831006 for the soft ones. Thanks, might have a look at these aswell since the Mickey Thompson tires was a bit smaller then I thougt. 90mm might just be the sweetspot. Share this post Link to post Share on other sites
Busdriver 6209 Posted May 1, 2020 Glad it worked, love to see a picture. Share this post Link to post Share on other sites
Dandy 5 Posted May 7, 2020 On 5/1/2020 at 9:59 AM, Busdriver said: Glad it worked, love to see a picture. See picture Share this post Link to post Share on other sites
Busdriver 6209 Posted May 7, 2020 They look really good. Have they got the foams in? What are they like in use? Share this post Link to post Share on other sites
Dandy 5 Posted May 7, 2020 Thanks! Yes, I got the foam in them but they are still almost to soft I think but they do give the truck aswesome grip. I do wish they were slightly larger though. They are around 84mm but 90mm would be the sweetspot I think. Share this post Link to post Share on other sites
Busdriver 6209 Posted May 7, 2020 I used them on 1.55 rims on my defender but they just didn’t look right, but as yo really good grip. I’ve now got them on my little pumpkin trail truck on an m chassis and they are spot on, but then it’s 1/12 rather than 1/10 Share this post Link to post Share on other sites
