Picked up 2 cars and a box of shells and wheels a few weeks ago
thought it was only fair after tending to the REELY carbon fighter that the grasshopper should get some attention too
it’s pretty tatty
shell cracked
chassis intact but v tatty
tyres perished
wheels painted with humbrol
no motor
A friend has an original release grasshopper that he’s rebuilding and bought a rere kit for the few spares he needed so I’ve bought and traded with him bits he didn’t need
got new tyres on the way, pearl white TS spray and some Kawasaki green for bits and bearings too ;)
in the mean time - full strip down and clean of parts I’m keeping
Then I attacked the wheels with some paint stripper
really testing my patience ;)
but I’ll stick with it for now
Just waiting for some more bits to come so I can get stuck in
JJ
Rebuilt the gearbox today with bearings and new casing
With original 380 sourced for originality
And attached to the brand new chassis
Side bars cleaned and refitted
along with the servo then the lower suspension arms
then I got bored and the wind had died down so I gave the shell a few coats of primer
(I’d previously shaved all the mould markings off to make it as clean as possible)
then 5 coats of pearl white
I wish I’d have filled the roll bars - May still do that as they are already bugging me
more tomorrow :)
JJ
Just giving the tatty wheels a coat of primer and having to just go with them due to costs
waiting to get hold of some decals and the box from the rere my friend doesn’t need
JJ
Getting closer to the end now
got my wheel screws so started to build up the 3 piece ones
I saw some people who were struggling so thought I’d do a mini guide
fronts:
squeeze tyre to elongate
this allows you to push the wheel in a bit more
Pull the rubber of the tyre at the top over the wheel
Then the bottom
and the same for the other side and the wheel is inside the tyre
you can then rotate it :)
Rears:
defo harder but same principle
just need to do the top a bit then the bottom a bit
rotate the wheel in while pulling the rubber out
et voila
added some Castrol Oil spotlight decals to continue the green theme
also added some white detail to the wheel rims
looks pretty good
JJ
Just grab the tyre edge and pull it towards you - id say adding soap won’t work as you can’t grab the tyre and the tyre will keep slipping back
dry would defo be the best
tool me 30 seconds per wheel
JJ
Well the grasshopper is alive again (well no radio gear but she’s certainly looking way better)
not box art but simple and fresh
ive found it an interesting refurb and it’s defo a basic model aimed at new builders.
but it’s great fun and the pre-cut decals help lots when your eyes are tired :)
i did trim them closer to help them fit better :)
JJ
