I've recently applied the best decals I've ever done on my new nova fox and am looking for any tips to prevent the decals from lifting. So far, I'm just pressing down on the potential problem areas (the corners and any on uneven areas of the body) every day to make sure they are firmly stuck on the body. Is there any kind of spray you can use on the top of the body to  make them stay stuck on ?
3 minutes ago, Nobbi1977 said:
A light going over with a hairdryer can help them stick, or restick if they are lifting
Thanks Nobbi! Best of luck with your RF sale, hopefully you get a solid amount for it to donate.
Hairdryer is the best advice.
You'll notice that with enough heat, the decals will have a very slight 'orange peel' surface to them once blasted with the heat of a hairdryer at close range.
The other advice is to always ensure you cut to a curve. Never have any sharp corners on the decals you are applying - even if that means adding radius into the clear section surrounding the decal. Better to have consistently rounded corners without any weak points where the decal can catch on things and start to lift.
