padrc66 10 Posted April 27, 2020 Okay, a little bit of artistic licence with the title, this is a re-release Bigwig but the original Bigwig was 1986 and the Leonis 2011 so close enough. no build pictures I'm afraid but i've just put the finishing touches to these 2 and painted them in the same colours as a bit of a link. The Bigwig is fairly standard with Hotshot driveshaft, front CVDs and steel pinion. The Leonis is a bit of a mixture, started with a car that i got from eBay that was probably built from spare parts, all new and unused but lots of hop-ups and some bits missing. I've added some new parts and 3D printed some parts that are now unavailable so as far as I can tell: Carbon reinforced main chassis, gearboxes, steering linkages, towers. TRF rear wishbones Slipper clutch and CVD propshafts and driveshafts Alloy steering rack and rear toe bracket As I had to 3D print some new battery brackets anyway (no longer available) I took the opportunity to put in a saddle pack battery and use the standard rear gearbox (on the parts sprue) to straighten up the rear driveshaft, hopefully clear from the pictures. 6 Share this post Link to post Share on other sites
