Does anyone know much about them, i.e wheelbase and what bodies fit etc? Looking at one on ebay at the minute and wondering if i could make something of it. Any info a help, thanks
Body mounts are in the standard Tamiya locations, track width is in the 180mm to 190mm range depending on your wheel offset, hex thickness, etc. You can also get longer axles to add another 5mm or so of width. So you have a huge range of bodyshell options from Tamiya and 3rd part manufacturers.
Any body that fits the TT02 will also for the TT01E, assuming it’s the same wheel base. I have both the 01 and the 02 built to 257mm wheel base  and share bodies between the two
