This may be one for TRF guru @qatmix :D
I have a second-hand TRF416 which came with these aluminium rear uprights. I'm not sure which variant of the 416 it is, but I understand they all came with plastic versions of this as standard (51333).
I've searched and not found anything that matches. There's no markings, not even an indicator of toe-in, like on the alu uprights on the 49400 934/TA-05MS I have here. 10mm bearing.
Are they a Tamiya part or something from a third party (Yeah Racing / Jazrider)?
Thanks!
I don't think they are Tamiya as I never seen the raised section around where the grub screw sits.
Could be wrong!
Thanks guys!
If they're aftermarket then they're not going anywhere near my project :D
I'd seen the TB-03D ones which will fit, but I need zero degree. I guess I could fit 1° then correct back to zero with a narrower rear suspension block.
