1 hour ago, svenb said:
Very nice indeed 👍
Don't forget the tungsten diff balls, aluminuim pressure plate set, aluminium front uprights and aluminium hub carriers 😳
I fancy a LiFe battery, where did you get yours from?
And alu knuckles - 53325 👍
Oops I meant front knuckles not uprights 🙄
Sorry - yes @svenb, I missed off the tungsten thrust + diff sets ... already on order sir 👍
Sadly can’t find an NIP aluminium pressure plate set anywhere ? probably because TFE restorers hoover them up for silly money 😂
Any leads or tips finding one v much appreciated ?
This is going to be as close to the TRF 415MSX / TA05 30th Ann as I can make it guys but I’m hesitant about front end aluminium @svenb @futureworks ?
It clearly looks amazing but also adds weight - and in other builds has made 4WD over steer whilst transferring stress to other bits that are an absolute pain to fix ? Whereas the 49400 anticipated that issue with a suspension alloy anchored directly to more of it carbon !
Anyway, happy to be disabused if you guys have diff experience ?
The LiFe and charger had to come via a Japan broker @svenb - and was annoyingly one of the most expensive bits to keep the build true Tamiya 🙄
Let me know if you want a set sir I’ll add to my order before shipping 👍
More period hop-ups:
  • 49046 5mm Adjuster (Red) (I have no idea where you'd find these ;))
  • 49142 Lightweight Aluminum Wheel Hub (Thick)
  • 53167 Touring & Rally Car Ball Bearing Set (you could probably piecemeal a complete set relatively easily since the carbon shaft set replaces the hollow steel shafts that come with set)
  • 53214 Super Grip Radial Tire
  • 53321 Super Grip Radial Tires, Wide
Oh, and one other chance to "go blue":
  • 53130 Nylon Parts Coloring Set (you could dye both the high speed gear set and hi-torque servo saver :D)
And I know that you've already made a decision on the battery pack, but will add these to help complete the list:
  • 55051 1400SCR Battery 7.2V 1400 mAh
  • 55054 1400NP Battery 7.2V 1400 mAh
  • 55056 1700SCR Battery 7.2V 1700 mAh
  • 55062 1700SCRC Racing Pack 7.2V 1700 mAh
  • 55065 RC1700SP Racing Pack 7.2V 1700 mAh
  • 55071 RC1400SP Racing Pack7.2V 1400 mAh
One other I wanted to mention:
  • 49559 Plated Mesh Wheel
Granted that the wide rear wheels sort of make this a stretch, I thought maybe replacing the stock wheel centers with the plated items would be a neat substitution. I also might know where you could find the centers alone B)
Can you imagine how badass a car is going to be with parts called "tungsten thrust" in it!!!
Posted (edited)
I have to be honest here I've never ran a chassis with the aluminium knuckles 😳
Really quite rare and a bit pricey, mine on a couple of shelf queens.
I get what you mean about transferring shock to other components maybe that's why there haven't been that many aluminium hop up knuckles for many other chassis's, M-chassis and TL01 spring to mind🤔 probably a few more but don't see many TRF's with them on.
PM on its way👍
Is your mail box full buddy?
Edited by svenb
Mind blowing 😂
On the other hand, those cast pieces are soft as cheese compared to machined aluminum. I think you'd probably snap those knuckles before anything else ¯\_(ツ)_/¯
No no no definitely don't want that😲
It looks like the 54484 mesh wheel set for the CC-01 has the same plated centres and (I think) the 26mm rim.
Here's my Hopped-Up TA-02:
- 47396 FRP chassis with sanded edges
- 47396 FRP shock towers with sanded edges
- Custom chassis graphics
- 47393 High speed gear set
- 47395 Front one-way
- 53056 Metal wheel hexes
- 50705 Black steering knuckles
- 53155 Low friction alu dampers
- 53163 Red springs
- 53697 Super Stock RZ motor
- 45028 TEU-302BK ESC
- 55051 1400SCR Battery
- Full bearings including steering
- Hard prop shaft (polished)
- Adjustable upper arms
- Alu Motor mount
Centers are the same but the rims are different than the 49559 pieces. The originals came with Celica rims that were plated matte silver. :D
Ahh yes, I meant they are the 26mm rim for the 934/GT2. The 49559 are essentially a plated version of 53107 Skyline GT-R Mesh Wheel (but I'm sure you knew that!) :D
Pity the centres aren't available separately!
Or are they!?
Or are they!?
Not as far as I know. I bought the full set of tires and rims because apparently I'm a masochist 😂
This definitely looks like a ‘build to run’ project, but even though it’s with a re-re rather than original TA02 chassis, I’d still plump for a good old period correct brushed acto power 😊
Agree they’re superb @futureworks
Could a TEU302BK handle the power though ?
Its rated to 23t and these old Acto’s look to push out more ?
If so, that would m make for a v expensive Volac MS given I like to keep things red n blue 🙄
They are 15 turn if I remember correctly,
ESC to suit is the CPR 160, But it's not red and blue 😲
    • IXLR8  »  Clappy75
      Hi Jon,
      https://flic.kr/p/2roEkj2
      Doug
      · 0 replies
    • WhteRbt
      · 0 replies
      · 0 replies
      Hello
      Hope you are well
      Thank you for your help
      Kind regards
      Jack
      · 0 replies
    • seoondaddy
      Seo-onDaddy - YouTube
      · 0 replies
