PaulRC10 60 Posted May 3, 2020 I have seen some people use Threadlock on both re-re and original (restore) builds. I have never done so, despite being sorely tempted on at least one chassis. I have always assumed the compounds would likely be unkind to plastic over time. Any experience to share? Avoid? Use where necessary? Use by default? Share this post Link to post Share on other sites
Collin 902 Posted May 3, 2020 Only if needed. I rather prefer to lose one screw than not being able to replace it in the field. If a screw or nut is permanently getting loose, I put a drop of mid-strenght on it. Only rear wheel nuts gets always a drop. And the hex with spline inside. Other with my motobike. Every single screw a drop. Share this post Link to post Share on other sites
Oneball1971 126 Posted May 3, 2020 Should only need it on nut and bolt fixings really, metal to metal where they could vibrate loose. Share this post Link to post Share on other sites
futureworks 332 Posted May 3, 2020 If you ever sell a model on, the buyer if dismantling the kit will thank you for not using thread lock, particularly on grub screws 👍 Share this post Link to post Share on other sites
PaulRC10 60 Posted May 3, 2020 2 minutes ago, futureworks said: If you ever sell a model on, the buyer if dismantling the kit will thank you for not using thread lock, particularly on grub screws 👍 I wouldn't want to drill one of those out. Thanks guys, confirmed my thinking. Share this post Link to post Share on other sites
howaboutme 215 Posted May 3, 2020 As mentioned, only metal on metal. Only use a tiny amount. I typically drop some on a Q-tip and then run it onto the groves or nut. Even on grub screws. If used right, it shouldn't take too much force to "break the seal". If too much, heat it up first and then turn. 1 Share this post Link to post Share on other sites
toyolien 1012 Posted May 3, 2020 Always. Especially on grub screws. You'll only have an issue removing it if you either use too much, or use the wrong kind. I did read somewhere that the Tamiya threadlock is ok coming in contact with plastics, but it's still best not to. 1 Share this post Link to post Share on other sites
PaulRC10 60 Posted May 3, 2020 Hmmm. I might order tamiya and give it a shot on some of the grubs & 3mm nuts that keep loosening up. Thx. Share this post Link to post Share on other sites
howaboutme 215 Posted May 3, 2020 3 minutes ago, PaulRC10 said: Hmmm. I might order tamiya and give it a shot on some of the grubs & 3mm nuts that keep loosening up. Thx. you don't need name brand. i buy mine at the hardware store. #243 / blue (loctite is a brand not sure if you have them worldwide) is the right one. there are others that are higher in strength for other uses, like 262 (high strength) or 648 (bonding for bearings) , for example. 1 Share this post Link to post Share on other sites
CoolHands 570 Posted May 4, 2020 I use blue tamiya threadlock. It is quite gooey or ‘gluey’ compared with proper loctite, so I seem to be able to remove screws without problem. (I only use on metal to metal though, not plastic) 1 Share this post Link to post Share on other sites
toyolien 1012 Posted May 4, 2020 2 minutes ago, CoolHands said: I use blue tamiya threadlock. It is quite gooey or ‘gluey’ compared with proper loctite, so I seem to be able to remove screws without problem. I've only just discovered Tamiya threadlock. It is quite gooey but I think I prefer it to locktites. And it smells nice too. 1 Share this post Link to post Share on other sites
speedy_w_beans 3925 Posted May 5, 2020 The tube of Permatex blue thread lock gel I have says not to use on plastic parts. This is pretty consistent with what I've read/heard for most thread locking compounds. I'd avoid using it except for metal-metal interfaces. 1 Share this post Link to post Share on other sites
Nicadraus 1914 Posted May 6, 2020 I never used thread lock. Share this post Link to post Share on other sites
Howards 254 Posted May 7, 2020 Yes, use 242 on metal to metal fixings. Just a tiny, tiny spot. If you wanted to be conservative, but are running the car, I'd suggest 242 on any metal to metal where one part is a custom fitting that would be a PITA or expensive to source should it fall off 1 Share this post Link to post Share on other sites
martinjpayne 209 Posted May 7, 2020 Yes, Loctite 222 (purple) for metal-to-metal fasteners... Loctite 242 is really too strong for what we do, being for 6mm or larger threads. Share this post Link to post Share on other sites
Falcon#5 455 Posted May 7, 2020 Blue Loctite on metal to metal. Stay clear of the red stuff! If I have pesky screws embedded in plastic that keep coming loose, a tiny tiny drop of CA glue fixes that. (this advice is general in nature and Falcon#5 accepts no liability, responsibility or recourse) But a regular going over will identify which and what is coming loose, and nip them up accordingly. 2 Share this post Link to post Share on other sites
Big Jon 268 Posted May 11, 2020 I use a tiny dab on all metal-to-metal fasteners, unless there's a locknut. A dab of medium CA on screws threaded into plastic that keep loosening, although that's not a frequent occurrence. A little green Loctite (one drop) on the motor shaft before you install the pinion will help keep the pinion on in big horsepower applications. Think 1/8 and larger and six or more cells. Even with 5mm motor shafts and two set screws, the pinions still fall off sometimes. Those things will spike at over 2000 watts- almost 3 hp- so there's a lot of stress on a small part. Share this post Link to post Share on other sites
PaulRC10 60 Posted May 13, 2020 Just in the middle of a Kyosho Turbo Ultima build and it includes threadlock in the kit. Only directed to use where the screws terminate in a plate or non locking nut. Do Tamiya don’t supply / recommend threadlock in their kits do they? Share this post Link to post Share on other sites
howaboutme 215 Posted May 13, 2020 4 minutes ago, PaulRC10 said: Just in the middle of a Kyosho Turbo Ultima build and it includes threadlock in the kit. Only directed to use where the screws terminate in a plate or non locking nut. Do Tamiya don’t supply / recommend threadlock in their kits do they? Because not needed on plastic. In fact, discouraged. Only metal to metal. Share this post Link to post Share on other sites
Juhunio 1203 Posted May 13, 2020 2 hours ago, PaulRC10 said: Just in the middle of a Kyosho Turbo Ultima build and it includes threadlock in the kit. Only directed to use where the screws terminate in a plate or non locking nut. Do Tamiya don’t supply / recommend threadlock in their kits do they? I got some red Tamiya threadlock with my BigWig rere, which I think was just for the small screw that holds the bumper in place. The Boomerang rere has the same screw and the manual asks for threadlock but there was none in the kit. There was none in the DI kit, but I did use some left over from the Bigwig on the metal-to-metal connections, like hop up aluminium knuckles / 5mm ball connectors Share this post Link to post Share on other sites
Finnsllc 609 Posted May 14, 2020 ran my sand viper today, spent 10 min looking for the dogbone after the assembly lost a screw, went to put it babk together only to find i also lost the gearbox joint. went back and amazingly found it by second base. Anyway, one screw and alot of trouble later now thread locked in place Share this post Link to post Share on other sites
PaulRC10 60 Posted May 14, 2020 3 hours ago, Finnsllc said: ran my sand viper today, spent 10 min looking for the dogbone after the assembly lost a screw, went to put it babk together only to find i also lost the gearbox joint. went back and amazingly found it by second base. Anyway, one screw and alot of trouble later now thread locked in place Lucky! That happened to me on my original hotshot. Before I knew that people used threadlock. I shelved it for fear of losing bits l. I think it’s worth going back over my other kits now. Share this post Link to post Share on other sites
EvilSpike 174 Posted May 18, 2020 I will be from now on. I spent an age staring at gravel in the carpark on Saturday looking for the lower shock mount bushing after taking my Terra Scorcher out for its first run. Just a tiny amount of 242 on the threads of bolts before they go into flange nuts. 1 Share this post Link to post Share on other sites
