Hi guys, just a quick one, would like some suggestions, I currently have a tt02, pretty much everything I can do has been done to it,  gears, everything alley&carbon  although I know some wouldn’t agree with it! I like the look, I currently am running a 2s lipo alongside this brushless set up, I just want more power and speed, although the esc is compatible with 3s Lipo I would like a better motor, any suggestions  please! All differential gears have been up graded, along side prop shaft, oil filled shocks, all the wheel hubs are alley, carbon dampers, alley wheels, bearings, the lot, I just want more speed 😂 cheers guys
My suggestion would be to find some 48 pitch gears, the smallest spur and largest pinion that would fit in the gearbox. Just look for a spur that has the corresponding holes to mount up on your gear shaft. Can't remember what the biggest pinion that fits but it is easily located knowledge on this forum. If you modify the gearbox you can fit a pretty big pinion. I would pair all this with a high turn (low KV) brushless motor.
