2 minutes ago, Problemchild said:
This is the full fat 540 one
Darn . I've bought skimmed and I could have bought full fat for £2 more - I might pull the trigger
13 minutes ago, KEV THE REV said:
Ah , hence the cheapeness . Oh well I'll try it out and go from there - I don't expect the thunder of your B/L
Trust me - that goolRC will be better
try the skimmed one first
JJ
7 hours ago, TheMidnight Pumpkin said:
I have a question. Do you think diff putty would stop the clicking, since it would change how the diff works as opposed to the printed gear box braces?
I would think putty would make it worse.
As we all know, the problem is that the side plates flex under load allowing the diff gears to loosen up to the point where the teeth skip. I think adding something too tacky would cause the gears to spread more worsening the issue.  But to be honest, I’m not sure.  I have no experience with putty.
In my current BF build project, I used a thick silicon goo, but very little of it.  But I’m using the MHeald plates to help with the flexing issue.
Terry
We are going to test 2 more versions
an additional 0.2mm and a 0.4mm pressure :) this will allow is to work out the best level of pressure
I think we have it but it’s always best to test a few more versions to make sure we get the best out of the brace :)
JJ
So I’ve been testing the initial prototype hard for a week
grass is the worst surface for the diffs
both the blue version being used in the vid (tarmac and woods) and the original 2 piece brace have clicking on the grass.
here are some pics of the blue one
This is what you will get in the kit...
And here it is fitted to the beetle
we’ve tried a set up that clamps the diff fully until it doesn’t move and I’ve just received today v.6 with 0.0mm, 0.2mm and 0.4mm degrees of additional clamping.
plus I have the brat/frog version for fitment testing.
should have some more results after the weekend
Thanks for your patience peeps
JJ
It´s a well made construction and design, but you Maybe should also think About the bearing Nylon housings, the white ones. They have very few material to hold it against popping out of the side plates. There may be some flex left, you do not catch with your braces onto the aluminum side plates.
Hope you know what I mean. Maybe there is some improvement potential left.
Kind regards,
Matthias
Kind regards,
Matthias
Hi,
Yes that is a very good point. I'll take a look at that piece see if there is any room for improvement. Its a fairly tight fit in the pressed pate so it might be hard to get more material in there but I'll take a look.
Pete
Yeah agree - there is only about 1mm there but can certainly be looked at.
the main approach has been to limit flex across the long metal side plates
cant wait to try the next versions
more pics and vids coming soon - go away rain ;)
JJ
Test fitting of the brat/frog version of the brace that wraps around to protect the gearbox from grounding
This wrap around version will also be able to be able to be purchased (in red and black)
Thoughts??
JJ
Yeah course - we aren’t gonna hold anyone to anything - it was just to get an idea :)
just dealing with dogbone issues and a snapped servo horn - the beetle is too fast and take a few too many hits ;)
JJ
Yeah, I really like that last design that goes all the way around the bottom - got 2 beetles in the pipeline that will need them when you are satisfied with your design - really impressive work there!
I have beetle issues at the moment
testing is on pause
I snapped a servo output shaft (innocuous hit) and then all the electronics started glitching which I think was a dying ESC as it was taking a lot of draw through it (connector, motor and ESC getting hot)
awaiting some new parts but I’d given it a good smashing in the park with no issues apart from the CV joint binding (will post a vid in a bit)
JJ
