ChrisHGTV 37 Posted May 23, 2020 Hello all Well I thought the lockdown was the perfect opportunity to give my old Sand Scorcher some much needed TLC! I'm 48 and I got my SS around my 10th Birthday I think, I can't remember exactly so maybe 1982 or 1983. I do remember pestering my dad to build it on Christmas day! It was going to be candy apple red, and I remember me and my dad went to this proper bikers custom paint shop to get the paint. It needed a gold base coat which was fine but the flake in the red was so big it wouldn't go through dads spray gun - so it ended up white and red! When I retrieved it from my folks (before the lockdown) it was in a sorry state - the tyres had perished, wheels were cracked, front windscreen had a big hole in it. I felt quite guilty and when I realised some parts were still available I thought i'd bring it back to life. And I didn't realise there was such a following for the SS! So this is what I've done over the last few weeks: Completely disassembled it, cleaned everything and polished the aluminium bits New wheels and tyres Made a new windscreen from some acetate sheet i found Cleaned the shell, touched in some of the paint, lacquered, wet sanded and polished before waxing. I wanted to keep the "patina" - warts and all! polished the servo/battery box with Meguiars plastic polish as well as the remaining window glass - worked a treat though the windows are still very yellow - but shows it's age! New o-rings for the shocks, filled with a sludgy mix of bike grease and oil Added ball races in place of the old oilless metal bushes - gearbox and wheels New cables for the motor Added an ESC - i just went for a Tamiya TEU-105, and removed the old 4 x AA batterys. Works fine. Replaced the servo tape on the steering servo New rear bumper - the old one was destroyed New rubbers - the switch cover and shock mounts New motor and gearbox plastic covers as the old ones were very brittle The white plastic ball races for the front uprights were really worn so i bought some rere ones. But they don't fit the old arms - and the old ball sockets are 3mm, not 4mm like the rere. So i bought some 4mm rere ball connectors and drilled out the uprights slightly so they accept the rere ball races. Dead easy and works well. So I ran it a few times and it bought back so many memories! Unfortunately the front bumper broke - on inspection it was carrying a very old injury! So I made one out of aluminium. I'd also read that the chassis flex can stress the shell so I made a strengthening plate out of ally, and shaped it so it matches the sills on the shell. I'm really pleased with it I also have a couple of Kyosho mini-z cars so managed to get one of the controllers to work with the SS in place of the old Acoms stick transmitter. I had to swap the channels round on the receiver but all works well. I'm determined to use this SS as a runner - this is why my folks bought it for me, so I want to honour that! But I want to preserve the shell so have bought a rere shell that i'll paint and will use that for running. Still a couple of bits to do - I need to make a sunroof, and will fit the exhaust from the rere bodyshell I have. Here's a few pics... 4 Share this post Link to post Share on other sites
ChrisHGTV 37 Posted May 23, 2020 I forgot a few things - when dismantling, one of the rear arm grub screws was seized - typically on the side I needed to remove to access one of the bolts to separate the gearbox. I tried drilling it out but ended up having to saw it off - so bought two new arms. They're actually MK1 arms with the recess for the second set of bearings. I also needed a new torsion bar as I had to saw through the original. Also, I needed to get a new battery and charger to replace the old NiCd. I've gone for an Overlander Tornado 3300 7.2V NiMh and fast charger. I also needed more of the camlocks for the battery box I hate to think what I've spent on this so far but it's worth it! And my dad has been really pleased to see it running again! Attached a photo of it over the woods near us - great fun but the sand gets everywhere so had to strip down the gearbox to clean after a couple of runs And a piccy of the new rere ballraces installed in the old uprights 1 Share this post Link to post Share on other sites
SuperChamp82 743 Posted May 23, 2020 First of all welcome to TC @ChrisHGTV By the sound of those two posts you’ve found a perfect home sir 😂 Others will chime in with suggestions on what next but, for me, you’ve had fun doing exactly what anyone coming back after a while should do ! Look, clean, polish - work around the problems - then run 👍 It’s all how we first enjoyed the hobby back in the day - probably with our Dads - and you’ve enjoyed the perfect start ! 1 Share this post Link to post Share on other sites
ChrisHGTV 37 Posted May 23, 2020 Thanks for the welcome! Yes it’s rekindled my interest again for sure! I’m already thinking of getting another buggy of some sort. I can see it’s a bit of a slippery slope! 2 Share this post Link to post Share on other sites
SupraChrgd82 1425 Posted May 23, 2020 Tamiya is making an updated ball diff for the SRB's 1 Share this post Link to post Share on other sites
ChrisHGTV 37 Posted June 2, 2020 Well to preserve the original shell I bought a rere for running and painted it up in Candy lime green and metallic red, with a mica silver stripe between that allowed me to mask each colour, as I wanted silver as a base for both the red and green. Then a good splash of TS-13 lacquer on top. Still a few bits to finish but i'm pleased with it! I also re-modelled the front guard I had made so it's less cumbersome looking. Next up is some brat wheels and tyres - I can't find any wheels in stock anywhere at the moment, just the tyres. :o( Then I like the idea of replacing the shocks with something that actually dampens the suspension - the rear is especially bouncy. Can anyone recommend anything? Ideally for front and rear. I've googled but there seem to be a number of options. I'm more interested in the damping than the spring, as i'd be happy to leave the torsion bars in place. 3 Share this post Link to post Share on other sites
Shodog 1835 Posted June 2, 2020 Looks great so far. I would suggest an aluminum chassis. Your home made skid stiffens the chassis but an aluminum chassis would stiffen it further. A flex chassis is the number one reason bodies get broken. Share this post Link to post Share on other sites
ChrisHGTV 37 Posted June 2, 2020 Thanks Shodog. The chassis plate I have added (in addition to the front skid plate) is super rigid - it doesn't flex at all now. It's also bolted through the original fiberglass chassis plate - if I crack the shell now I think I deserve it for being too rough on the old girl! I've just added some decals and race numbers. I'm not sure about the rere decals, i was going to buy some repro versions of the originals but i'm trying to not go overboard on this shell as it's supposed to be my runner! I don't want to end up being too precious about it. It's quite interesting comparing this rere shell with the original. The original does have a much nicer shape to the fenders I think. And I think i'll paint the wing mirrors, they look a bit too toy like in the all-over chrome. Really pleased with the paint though, the photos don't really do it justice - the green is amazing in full sunlight. I wet sanded the body to remove the mold lines and give a good key. I then shot over with Tamiya fine primer, then wet sanded with 2000 grit. Then a few coats of mica silver. I didn't wet sand the silver as I thought it might dull the metallic effect. Then masked up for the green - about 4 coats. Then when dry masked for the red, same 4 coats. Then a very gentle wet sand with 2500 grit and a few coats of TS-13 lacquer. Needed very minimal polishing then. The masking took a while - mainly going past all the ridges by the windows, I burnished the tape with a plastic tooth pick - I only had two very small bleeds which were easily rectified with a scalpel blade. I used 3mm and 10mm Tamiya tape. Oh and before each colour I blew over the tape very lightly with whatever colour was underneath to seal the tape. Whatever, it seemed to work! Now just need some more wheels, for a change, and new shocks... 1 Share this post Link to post Share on other sites
ChrisHGTV 37 Posted June 2, 2020 Added a few decals... 3 Share this post Link to post Share on other sites
