Tommy88 0 Posted May 23, 2020 Hello everyone, I’ve just joined as like others (I expect), the lock down has caused me to go down memory lane and get back into RC cars. My first was a Falcon back in the early 90’s. I am hoping someone could provide me with some much needed advice, please. Im currently trying to get my mates Lunchbox to run. He bought it off eBay, it had an old MSC (now replaced with an official Tamiya ESC), but every time I turn it on, it keeps flinching/glitching, with some of my commands being met, then it gets erratic, and can zoom off by itself. Please, does anyone know what a solution could be? Servos are still the originals from when it was first assembled, and the transmitter is an old Acoms 27MHz with matching crystals (No. 6, Blue), stick type. Reciever is the old one, maker is ‘Beat2’. Should I replace the steering servo and also transmitter/receiver. Any help is greatly appreciated. Share this post Link to post Share on other sites
Problemchild 1770 Posted May 23, 2020 Is the ESC set up to match the motor? ie. brushed or brushless JJ Share this post Link to post Share on other sites
Tommy88 0 Posted May 23, 2020 Not sure, thanks I’ll check. Also, with the old MSC in, the vehicle did the same thing. Ie was erratic and zoomed off, steering glitching etc. Share this post Link to post Share on other sites
Problemchild 1770 Posted May 23, 2020 Ah ok transmitter receiver issue then JJ Share this post Link to post Share on other sites
Tommy88 0 Posted May 23, 2020 Thanks so much JJ, thats what I’ve been thinking too T Share this post Link to post Share on other sites
SupraChrgd82 911 Posted May 23, 2020 I'm old enough to remember non-2.4 radios.... Some general rules old TX/RX gear: never alter the antennas on the TX or RX use the long antenna tube don't bunch up the RX antenna mount the RX away from batteries, speed controls and wiring tighten any metal parts on the car that may rattle or vibrate use fresh batteries don't drive under or above power lines keep 2-way radios and cell phones away from the RX These are all easy and inexpensive. Try these first, then look into new equipment. 2 Share this post Link to post Share on other sites
berman 3290 Posted May 23, 2020 The transmitter is an Acoms, the beat2 is made by JR propo, even if you have the same crystals, I think that is your problem. Acoms doesn't like to work with other manufacturers Transmitters or receivers. Buy a cheap 2.4ghz set and set up the esc again with it. If you are in the UK I believe these guys say the Absima are cheap and work well. Share this post Link to post Share on other sites
Tommy88 0 Posted May 23, 2020 Thanks all, noted on all the points made. ive ordered an Absima and will install that and recalibrate the ESC as suggested. Thanks again, T Share this post Link to post Share on other sites
Wooders28 3225 Posted May 23, 2020 9 minutes ago, berman said: Buy a cheap 2.4ghz set and set up the esc again with it. If you are in the UK I believe these guys say the Absima are cheap and work well. I've this up atm, pretty much the same as a basic ,old 27mhz radio, no frills. https://www.ebay.co.uk/itm/174286406374 1 Share this post Link to post Share on other sites
