Bromley 681 Posted May 26, 2020 I found a link to I believe a legit Tamiya source where you could input a chassis designation and find all available genuine hop ups. I can't seem to find it now. The Tamiya.com website is less than helpful. I'm interested in what is available for the CC02. Any help would be appreciated. Share this post Link to post Share on other sites
ChrisRx718 4470 Posted May 26, 2020 Unfortunately the best place to look is on a shop, like RCMart, then filter it by manufacturer to see just genuine Tamiya Hop-Ups. So far for the CC02 you have: 54929 CC02 Stainless Steel Adjustable Tie Rod Set (this seems expensive for what you get!) 54945 CC02 Low Friction 6mm Ball Collars 18 pcs 54910 CC02 Ball Bearing Set 54944 CC02 Aluminum Arm Pivots A B Set And recently announced: 54970 CC-02 Aluminum Spur Gear Mount 54971 CC-02 Motor Mount Bridge Spacer I haven't upgraded my CC02 much yet, but I have reduced the wheelbase to fit a Pajero Hard Body. I might fit my Defender though, I can'd decide. I can see myself using the CC02 more than the CC01... 1 Share this post Link to post Share on other sites
jonboy1 2943 Posted May 26, 2020 have you tried googling tamiya matching list? there's a link to the 2019 version there - unfortunately it doesn't cover the CC02 chassis 1 Share this post Link to post Share on other sites
JeffSpicoli 1363 Posted May 26, 2020 what about Tamiyabase.com? 1 Share this post Link to post Share on other sites
ChrisRx718 4470 Posted May 27, 2020 19 hours ago, Mokei Kagaku said: I know you didn't make that list @Mokei Kagaku, but there is no way that any of those damper kits will work. The kit dampers on a CC02 are approx. 95mm long! 1 Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted May 27, 2020 5 hours ago, ChrisRx718 said: I know you didn't make that list @Mokei Kagaku, but there is no way that any of those damper kits will work. The kit dampers on a CC02 are approx. 95mm long! I have a CC-02, so I know, and I contemplated before posting the list whether I should do a little censorship , but decided against it. 1 Share this post Link to post Share on other sites
Rubyred 34 Posted May 28, 2020 Tamiyausa.com has a decent list of hopups. The link is at the kit page. 1 Share this post Link to post Share on other sites
