TurnipJF 9116 Posted June 18, 2020 We can go through the setup via WhatsApp again if you like. Let me know if/when you would like to give it a try. Share this post Link to post Share on other sites
Jay77 9 Posted June 18, 2020 Thanks, Keith! What time are you up till? It’s taken my half and hour just to remove the ******* grub screw from the old motor. Jay Share this post Link to post Share on other sites
TurnipJF 9116 Posted June 18, 2020 6 minutes ago, Jay77 said: Thanks, Keith! What time are you up till? It’s taken my half and hour just to remove the ******* grub screw from the old motor. Jay No fixed bedtime - let me know when you are ready. Share this post Link to post Share on other sites
Jay77 9 Posted June 18, 2020 Cool. It looks like I’ll need a longer shaft? Share this post Link to post Share on other sites
TurnipJF 9116 Posted June 18, 2020 You ought to be able to move the pinion further out on the motor shaft, so that the spacing between it and the motor backplate is the same as it was with the original motor. Share this post Link to post Share on other sites
Jay77 9 Posted June 18, 2020 Ah! Leave this with me! Share this post Link to post Share on other sites
Jay77 9 Posted June 18, 2020 Done. Motor mounted. It looks worryingly close to the shock. Share this post Link to post Share on other sites
TurnipJF 9116 Posted June 18, 2020 It should be no different to your previous motor in terms of spacing from the shock. If the spacing looks different, perhaps double check the mounting? Share this post Link to post Share on other sites
Jay77 9 Posted June 18, 2020 Hey Keith, I’m ready when you are. Jay Share this post Link to post Share on other sites
