Are there any spray paints other than the Tamiya PS range that are any good for painting the inside of a clear shell?
I specifically need metallic brown but could maybe lay solid brown over a pearl coat? Does that work?
Either way I can't find polycarbonate brown spray anywhere - anyone got any ideas please?
Depends where you are, but Duratrax and Pactra paints are still available.
https://www.testors.com/product-catalog/testors-brands/testors-pactra/pactra-3oz-sprays
https://www.duratrax.com/paint/index.html
A pearl coat will lighten any color applied to it.  So a brown will become a light brown or tan.
If you really need brown, you'll likely have to mix your own using Parma Faskolor or Liquitex primary colors and an airbrush.  BUT, check formulation because some of these may not stand up to impact damage.
I have used Core rc with mixed results
Pro-line do a metallic copper that you could darken. Need an airbrush to apply it though.
Wow!
I have not seen, heard nor read Pactra and Testors in a very long time. Last time was probably from the early-mid 80s when my dad used to build scale models and uses these paint brands. Because when I started building models in 1984 as a kid, I already used Tamiya enamel and acrylic.
5 hours ago, Nicadraus said:
Wow!
I’ve used the pactra/testors recently and it’s no where as good as tamiya. Takes a long time to dry and the quality just doesn’t feel as good as tamiya. Maybe it used to be real good but it’s owned by rustoleum now
As I said - rattle can ;)
Halfords will make up whatever colour you want
there was a thread about using car spray paint last month - quite a few people use it
guess it depends what you wanna use it for
JJ
Try Spaz Stix Candy Golden Rootbeer.  It's metallic and can be made lighter or darker brown depending if you back it with silver, white, mustard yellow, or gunmetal.
https://www.hobbyrecreationproducts.com/products/szx15659-golden-candy-rootbeer-aerosol
    • IXLR8  »  Clappy75
      Hi Jon,
      https://flic.kr/p/2roEkj2
      Doug
      · 0 replies
    • WhteRbt
      · 0 replies
      · 0 replies
      Hello
      Hope you are well
      Thank you for your help
      Kind regards
      Jack
      · 0 replies
    • seoondaddy
      Seo-onDaddy - YouTube
      · 0 replies
