BOARDRIDER 7 Posted June 11, 2020 Are there any spray paints other than the Tamiya PS range that are any good for painting the inside of a clear shell? I specifically need metallic brown but could maybe lay solid brown over a pearl coat? Does that work? Either way I can't find polycarbonate brown spray anywhere - anyone got any ideas please? Share this post Link to post Share on other sites
Superluminal 3750 Posted June 11, 2020 Sounds very 70s?? 1 Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted June 11, 2020 Depends where you are, but Duratrax and Pactra paints are still available. https://www.testors.com/product-catalog/testors-brands/testors-pactra/pactra-3oz-sprays https://www.duratrax.com/paint/index.html A pearl coat will lighten any color applied to it. So a brown will become a light brown or tan. If you really need brown, you'll likely have to mix your own using Parma Faskolor or Liquitex primary colors and an airbrush. BUT, check formulation because some of these may not stand up to impact damage. Share this post Link to post Share on other sites
Wetman 417 Posted June 11, 2020 1 hour ago, Superluminal said: Sounds very 70s?? I'm betting a Vauxhall Viva 😂 1 Share this post Link to post Share on other sites
Wetman 417 Posted June 11, 2020 1 hour ago, BOARDRIDER said: Are there any spray paints other than the Tamiya PS range that are any good for painting the inside of a clear shell? I specifically need metallic brown but could maybe lay solid brown over a pearl coat? Does that work? Either way I can't find polycarbonate brown spray anywhere - anyone got any ideas please? I have used Core rc with mixed results Share this post Link to post Share on other sites
Howards 456 Posted June 11, 2020 4 hours ago, BOARDRIDER said: Are there any spray paints other than the Tamiya PS range that are any good for painting the inside of a clear shell? I specifically need metallic brown but could maybe lay solid brown over a pearl coat? Does that work? Either way I can't find polycarbonate brown spray anywhere - anyone got any ideas please? Pro-line do a metallic copper that you could darken. Need an airbrush to apply it though. Share this post Link to post Share on other sites
Problemchild 2149 Posted June 11, 2020 I’d just get a rattle cam from Halfords bit then I’m a rebel hah JJ Share this post Link to post Share on other sites
Superluminal 3750 Posted June 11, 2020 4 minutes ago, Problemchild said: I’d just get a rattle cam from Halfords bit then I’m a rebel hah JJ 1 Share this post Link to post Share on other sites
Nicadraus 6198 Posted June 12, 2020 7 hours ago, speedy_w_beans said: Depends where you are, but Duratrax and Pactra paints are still available. https://www.testors.com/product-catalog/testors-brands/testors-pactra/pactra-3oz-sprays https://www.duratrax.com/paint/index.html A pearl coat will lighten any color applied to it. So a brown will become a light brown or tan. If you really need brown, you'll likely have to mix your own using Parma Faskolor or Liquitex primary colors and an airbrush. BUT, check formulation because some of these may not stand up to impact damage. Wow! I have not seen, heard nor read Pactra and Testors in a very long time. Last time was probably from the early-mid 80s when my dad used to build scale models and uses these paint brands. Because when I started building models in 1984 as a kid, I already used Tamiya enamel and acrylic. Share this post Link to post Share on other sites
rwordenjr 1890 Posted June 12, 2020 5 hours ago, Nicadraus said: Wow! I have not seen, heard nor read Pactra and Testors in a very long time. Last time was probably from the early-mid 80s when my dad used to build scale models and uses these paint brands. Because when I started building models in 1984 as a kid, I already used Tamiya enamel and acrylic. I’ve used the pactra/testors recently and it’s no where as good as tamiya. Takes a long time to dry and the quality just doesn’t feel as good as tamiya. Maybe it used to be real good but it’s owned by rustoleum now Share this post Link to post Share on other sites
Raman36 1656 Posted June 12, 2020 proline paint is a good option for Lexan. You need an airbrush though Share this post Link to post Share on other sites
Problemchild 2149 Posted June 12, 2020 As I said - rattle can Halfords will make up whatever colour you want there was a thread about using car spray paint last month - quite a few people use it guess it depends what you wanna use it for JJ Share this post Link to post Share on other sites
SupraChrgd82 1425 Posted June 13, 2020 On 6/11/2020 at 9:34 AM, BOARDRIDER said: Are there any spray paints other than the Tamiya PS range that are any good for painting the inside of a clear shell? I specifically need metallic brown but could maybe lay solid brown over a pearl coat? Does that work? Either way I can't find polycarbonate brown spray anywhere - anyone got any ideas please? Try Spaz Stix Candy Golden Rootbeer. It's metallic and can be made lighter or darker brown depending if you back it with silver, white, mustard yellow, or gunmetal. https://www.hobbyrecreationproducts.com/products/szx15659-golden-candy-rootbeer-aerosol Share this post Link to post Share on other sites
