Wal.d 7 Posted June 11, 2020 Hi . I have just trashed my diffs on my lunchbox mini. I am running sport tuned motor and 2s battery can you please tell if you can get upgraded diffs and any other upgrades and where I can get them. Many thanks because I am struggling Share this post Link to post Share on other sites
waterbok 1281 Posted June 11, 2020 I am not sure if the diffs are similar with the T3-01, there are strengthened gears and driveshafts available for the later. For the SW I only have seen cross joints. Share this post Link to post Share on other sites
waterbok 1281 Posted June 11, 2020 Diff appear to be the same so the T3-01 parts may do the trick. Share this post Link to post Share on other sites
bozatron 96 Posted June 13, 2020 You have two options: The official Tamiya hop up... https://www.rcmart.com/tamiya-t3-01-reinforced-differential-joint-pinion-set-54876-00082940 or there are aftermarket ones from yeah racing and hot racing https://www.rcmart.com/hot-racing-aluminum-differential-lock-spool-silver for-tamiya-t3-01-dancing-rider-ttdr125h-00077797 The yeah racing/hot racing ones say for T3-01 but you can see on the tamiya hop-up it mentions they work for both T3-01 & SW-01 Share this post Link to post Share on other sites
Wal.d 7 Posted June 14, 2020 On 6/13/2020 at 8:23 AM, bozatron said: You have two options: The official Tamiya hop up... https://www.rcmart.com/tamiya-t3-01-reinforced-differential-joint-pinion-set-54876-00082940 or there are aftermarket ones from yeah racing and hot racing https://www.rcmart.com/hot-racing-aluminum-differential-lock-spool-silver for-tamiya-t3-01-dancing-rider-ttdr125h-00077797 The yeah racing/hot racing ones say for T3-01 but you can see on the tamiya hop-up it mentions they work for both T3-01 & SW-01 Thanks this was sending me mad 1 Share this post Link to post Share on other sites
