hedge 314 Posted June 17, 2020 I think I must have a duff batch, can't get the tread going the same way no matter what I try. Has anyone got these tyres and have the same issue? Share this post Link to post Share on other sites
ChrisRx718 4464 Posted June 17, 2020 That's fine - you get that on road car tyres too; the pattern is just referred to as 'asymmetrical' where it can be used on either side. Tamiya make directional tyres too, like the Super Grip Radial and Racing Radial tyres. They're more expensive than the regular radial tyres you have there of course. It's fine 1 Share this post Link to post Share on other sites
TWINSET 1793 Posted June 17, 2020 This does not sit well in my brain, I like symmetry and geommetric alignment - I can spend ages aligning cutlery to mat edges etc. Trouble is, once you notice it, it's everywhere. Over the years, I've learnt to cope, but still not a fan 3 Share this post Link to post Share on other sites
hedge 314 Posted June 17, 2020 Thanks at least its not an error, but boy I would expect that to make the car "Crab". Ill be running them later and just wont be able to stop thinking.... "did it just crab a fraction of a mm..." arggghhhhh. I to suffer with mild OCD. Share this post Link to post Share on other sites
Gruntfuggly 562 Posted June 17, 2020 I know why you'd think that, but it doesn't really make sense - one tyre on it's own wouldn't crab, so two shouldn't make any difference? 1 Share this post Link to post Share on other sites
TWINSET 1793 Posted June 17, 2020 26 minutes ago, hedge said: ...but boy I would expect that to make the car "Crab". Ill be running them later and just wont be able to stop thinking.... "did it just crab a fraction of a mm..." I'm with you on that - chevron tyres are directional so they displace the running surface from the centre, outwards, keeping the vehicle running as straight as possible - I can't see how sideways-directional tread doesn't produce a similar effect 1 Share this post Link to post Share on other sites
Gruntfuggly 562 Posted June 17, 2020 OK, so now I'm doubting too... Share this post Link to post Share on other sites
ChrisRx718 4464 Posted June 17, 2020 The contact patch is too small to have any effect. The voids between the raised 'blocks' are for dispersing water - they can't 'disperse' the road surface, nor can this have any measurable effect on the lateral forces of the wheel, reality is that at 1/10 scale, it's largely vanity. A tread pattern may serve to help keep the tyres cooler on a hotter track, but ultimately just reduces tyre traction. The real reason for having a pattern is to mimic real-life cars. Best grip of course is a completely slick tyre, to maximise the contact patch. Share this post Link to post Share on other sites
TWINSET 1793 Posted June 17, 2020 If you take the Unimog; Looking from above, with truck front at top of pic, the running surface must displace off to the right when the truck accelerates (the left shoulder knobble hits the surface first) - that must have some effect (even tiny) on the straight line If you think of the tread bars as propeller blades, it makes more sense (to me) 3 Share this post Link to post Share on other sites
NobbySideways 113 Posted June 17, 2020 Are you able to run in enough of a straight line to find out if its a problem? Because I sure can't... 1 Share this post Link to post Share on other sites
TWINSET 1793 Posted June 17, 2020 I think there's enough slop in most Tamiya steering setups to hide any traction-based trajectory errors Share this post Link to post Share on other sites
KEV THE REV 2304 Posted June 17, 2020 7 hours ago, TWINSET said: This does not sit well in my brain, I like symmetry and geommetric alignment - I can spend ages aligning cutlery to mat edges etc. Not just me then I can see your theory behind the odd tyre pattern , and it makes sense to me too . The water displacement does appear to be one sided , but as it is small scale and various other factors come into play , like slack in model joints etc I wouldn't think it would make too much difference to the running - BUT IT ISN'T SYMMETRICAL !! Share this post Link to post Share on other sites
KEV THE REV 2304 Posted June 17, 2020 Got there before me Andy Share this post Link to post Share on other sites
Problemchild 2149 Posted June 18, 2020 It would take 2 sets of tooling and double the price of your tyres though so tamiya make 1 tyre pattern and you get 4 JJ Share this post Link to post Share on other sites
XJman 74 Posted June 18, 2020 Two of the tires should have been glued the opposite way 1 Share this post Link to post Share on other sites
Otis311 187 Posted June 18, 2020 The lack of symmetry has always bothered me as well. In practice it really doesn't matter. Most RC cars are asymmetric in many other ways that would have a much greater effect on performance. Share this post Link to post Share on other sites
