HouseRC 0 Posted July 4, 2020 Hi I’m about to start build a TT-02 based Porsche 911 RSR but I’m not sure on the; wheelbase, ride-hight and tread setting. I think it should be: Wheelbase = Short Ride-hight = Standard Tread = Standard If you built one or know the chassis configuration could you let me know if I have this correct. Thanks. Share this post Link to post Share on other sites
Shodog 1835 Posted July 4, 2020 You build it the short 251 mm wheelbase. You need to use the staggered wheel setup with wide wheels in the rear. the decals go on in a sequence. Put the stripes on first then the window trims 2 Share this post Link to post Share on other sites
