2 hours ago, tomjkear said:
Nice clear explanation, thank you!
Which one? The goolrc or the ebay link I posted?
Cheers :)
GoolRC combo...from eBay.
On 7/14/2020 at 3:23 AM, Re-Bugged said:
One of the reasons I went Hobbywing for my first step into Brushless was they are designed to fit together from the start which simplified things. Saving time and potential frustration for someone time poor like me.
As you pointed out the motor doesn’t normally come with the Yellow Blue and Orange wire. The wires come with/on the ESC generally.
If the TBLE 02 wires will reach the motor tabs, all well and good, just cut the Tamiya bullets off and solder on.
If they don’t reach they will need to be extended. Brass Bullets work well covered with a bit of heat shrink.
(sorry I can’t remember if they were 3mm or 3.5?)
Another nice touch for Hobbywing is where the wires are soldered to the motor tabs they are actually like a bullet connector too so if you need to change your motor the wires now just simply unplug no need to de-solder.
One last thing, you can’t trust ebay pictures. I clicked ‘Buy Now’ on a HW 13.5t Quicrun thinking it was an older red can as pictured, but turned out to be the newest black can type, bonus for A$55 shipped, they are now around A$80 from the same seller which is a shame.
Once again thank you for taking the time to explain the wire situation. Interesting, I really didn't get that you are supposed to solder them straight from the esc.
Now everything is clearer to me and I can venture on the online market and see what I find!
