Use stiffer springs at the rear.  The DT02 spring set (53832) will have soft and hard springs in the set.  Also use spring spacers to adjust the ride height a little.  You can lighten the rear end a bit by using the lightweight gear shafts (54560) and using the DT02 ball differential (53863) which is a lot lighter than the gear diff.  If you use the ball differential you will also need to change the drive shafts to dogbones or universal joints (53791)
11 hours ago, Roguet said:
I've got the Black Edition with the CVA shocks and have added the Hard springs from the DT02 hop up set and sits okay.
sorry for the off topic question, what are those tyres? they look awesome :D
That looks low, even for stock DT03 springs. Are you sure you’ve got the shocks built correctly?
I prefer the DF03 spring kit to the DT03 one, as the springs are silver or black rather than the garish red or blue.
If you're finding the dampers unresponsive now, I wouldn't put a thicker oil in them, at least not without fitting a stiffer spring.  I have mine filled with Tamiya #500  and wrapped with blue (stiff) springs.  It seems ok, but I might swap the stock pistons for something that can be better tuned.
Hi bozatron, they are the Duratrax Bandito.
Posted (edited)
Update.....
Had 700cst oil on order and red 'O' Rings...
Rebuilt rears today much happier with performance
Not sure i am going to need the harder springs 😬
Edited by Bennett Ironman
Added picture
Thanks for the info, I've ordered a set to try on my Blitzer Beetle :)
