Nicadraus 6198 Posted August 7, 2020 14 hours ago, ploots said: Is it an easy job shortening the servo wires,also I like that braiding where can I order that from 👍 Shortening the wires just requires soldering. If you know how to solder, you can do it. Use a 30w soldering iron to de-solder and solder the servo wires. 1 Share this post Link to post Share on other sites
ploots 185 Posted August 7, 2020 It's on my list of things to do thanks 👍 Share this post Link to post Share on other sites
Nicadraus 6198 Posted August 7, 2020 Finally finished installing the electronics. 6 Share this post Link to post Share on other sites
ploots 185 Posted August 7, 2020 What size is the braiding Share this post Link to post Share on other sites
Nicadraus 6198 Posted August 7, 2020 11 minutes ago, ploots said: What size is the braiding 6mm and 12mm 1 Share this post Link to post Share on other sites
ploots 185 Posted August 7, 2020 23 minutes ago, Nicadraus said: 6mm and 12mm 👍thanks Share this post Link to post Share on other sites
78Triumph 2610 Posted August 7, 2020 Wow! That's the cleanest looking wiring job I've ever seen! The matching color wire braiding is sharp! Well done, sir! 1 Share this post Link to post Share on other sites
rjg1973 159 Posted August 7, 2020 Very nice build, love the carbon. This may be a dumb question, but what bodies can you fit to an XV01? Would a TT01 spec Subaru WRX fit for example? Share this post Link to post Share on other sites
Nicadraus 6198 Posted August 7, 2020 1 hour ago, 78Triumph said: Wow! That's the cleanest looking wiring job I've ever seen! The matching color wire braiding is sharp! Well done, sir! Thank you buddy! 😉 1 Share this post Link to post Share on other sites
Nicadraus 6198 Posted August 7, 2020 57 minutes ago, rjg1973 said: Very nice build, love the carbon. This may be a dumb question, but what bodies can you fit to an XV01? Would a TT01 spec Subaru WRX fit for example? Yes, most (if not all) 190mm touring/rally bodies will fit the XV. 2 Share this post Link to post Share on other sites
rjg1973 159 Posted August 7, 2020 2 minutes ago, Nicadraus said: Yes, most (if not all) 190mm touring/rally bodies will fit the XV. Cool, thanks. Inspired by your work on this I reckon I’ll build an XV01 chassis for my Subie and go find some gravel. https://www.tamiyaclub.com/showroom_model.asp?cid=132869&id=29570 1 Share this post Link to post Share on other sites
ChrisRx718 4470 Posted August 8, 2020 10 hours ago, rjg1973 said: Cool, thanks. Inspired by your work on this I reckon I’ll build an XV01 chassis for my Subie and go find some gravel. https://www.tamiyaclub.com/showroom_model.asp?cid=132869&id=29570 I hope so @rjg1973 cos that's the same body I've bought for my XV01 Long Damper kit Currently still hiding it from my wife in the boot of my company car 1 2 Share this post Link to post Share on other sites
Nicadraus 6198 Posted August 9, 2020 Did a small detail add-on. Carbon fiber fan guard. Did the same to my FF-03Pro-R before. 3 Share this post Link to post Share on other sites
woppini 51 Posted August 10, 2020 What made you decide on that speed control. I have one on my crawler, but never thought about putting it on a roadie. Nice build by the way. Excellent attention to detail. 2 Share this post Link to post Share on other sites
Nicadraus 6198 Posted August 10, 2020 21 hours ago, woppini said: What made you decide on that speed control. I have one on my crawler, but never thought about putting it on a roadie. Nice build by the way. Excellent attention to detail. Thank you! As for your question, I have three 1060 in some of my kits. They're great. But I wanted something programmable, waterproof just like the 1060 and a little more appeal with reputable brand but not too expensive. I think the 1080 is the perfect choice. Can't go wrong at $40. Also, some of my friends run their XVs with this ESC which actually gave me the idea. I remember spending over $200 on an ESC back in 2006, the Twister 2.1 Hara (KO Propo VFS-1 Pro Competition). Now, I won't spend over $100 on an ESC anymore. Although I have two Toro TS160. But those were just given to me by a friend who owns one of the local hobby shops here. He used them for a race and he said he'd give me a brushless ESC and motor if ever I come back to the hobby. Which I did. 1 Share this post Link to post Share on other sites
Room335 738 Posted August 10, 2020 On 8/7/2020 at 6:13 PM, 78Triumph said: Wow! That's the cleanest looking wiring job I've ever seen! The matching color wire braiding is sharp! Well done, sir! x 2. You have some of the cleanest looking builds @Nicadraus. Great job! 3 Share this post Link to post Share on other sites
Nicadraus 6198 Posted August 11, 2020 9 hours ago, Room335 said: x 2. You have some of the cleanest looking builds @Nicadraus. Great job! Thank you sir! Share this post Link to post Share on other sites
Carmine A 2046 Posted August 14, 2020 TRYING not to beat the dead Horse in compliments.... I really wish there was a LOVE button!!! 😁 It's truly Art on Wheels.🏆👏👏👏 I THOUGHT I did neat Wiring, till I saw yours. I really wanted a FF-03 before, but now I'm anxious until I get the chance... I still haven't been able to get my FIRST HW-1080... 😞 I do use 1060s in nearly everything except my Wraith, which is Brushless. I had fitted a 1060 on my M05... and FORGOT I left the Drag Brake set!! 😲 You ever run a FWD Car with a Drag Brake?? It's a Hair raising experience! 1 Share this post Link to post Share on other sites
Nicadraus 6198 Posted August 15, 2020 Parts from RCMart have arrived. So I installed them on my and my friend's XV too. Rear carbon fiber shock towers Steel bevel gears TA-06/FF-03/FF-04/XV-01 Some 420 stuff for my FF-03 Pro-R Aluminum suspension mounts/blocks - This is a bang for the buck. I'm using original Tamiya on mine but this YR is just the same in terms of quality, accuracy and performance for less than half the price of the Tamiya. Installing steel bevel gears for the front diff on both kits... With 30k oil Two happy XVs - I also gave him my other carbon fiber bulkhead brace. 3 1 Share this post Link to post Share on other sites
Carmine A 2046 Posted August 15, 2020 SOME AWESOME FRIEND you are!!!! 😁😲 They both look so good. I am so jonseing for an Ex Vee Oh Three even MORE now! 1 Share this post Link to post Share on other sites
ChrisRx718 4470 Posted August 15, 2020 Looking great. I'm waiting on those same suspension blocks from Rcmart so again happy to read that they're decent. I would have gone 100% Tamiya but there were a couple out of stock. Have you seen the stuff for sale on AliExpress under the brand "TPRC"? They have a carbon front gearbox mount, carbon plate to go over the steering assembly, carbon towers front and rear, rear gearbox support and a bulkhead brace very similar to your design but with extra holes for mounting a fan. I've ordered the latter (£11) but can't afford to spend more on my XV at this time. The carbon parts would undoubtedly appeal for your build though! 1 Share this post Link to post Share on other sites
Nicadraus 6198 Posted August 15, 2020 51 minutes ago, Carmine A said: SOME AWESOME FRIEND you are!!!! 😁😲 They both look so good. I am so jonseing for an Ex Vee Oh Three even MORE now! Thanks! The XV is a fun kit to drive. It ca be very behaved and it can be wild. It'll do the characteristics you want it to do depending on your driving. I noticed that this car adjusts to your driving manner. Really impressive. 4 minutes ago, ChrisRx718 said: Looking great. I'm waiting on those same suspension blocks from Rcmart so again happy to read that they're decent. I would have gone 100% Tamiya but there were a couple out of stock. Have you seen the stuff for sale on AliExpress under the brand "TPRC"? They have a carbon front gearbox mount, carbon plate to go over the steering assembly, carbon towers front and rear, rear gearbox support and a bulkhead brace very similar to your design but with extra holes for mounting a fan. I've ordered the latter (£11) but can't afford to spend more on my XV at this time. The carbon parts would undoubtedly appeal for your build though! Yup I the YR suspension blocks are really nice. They are so worth it just like other YR parts that are actually good alternative for Tamiya. I saw the TPRC carbon fiber parts. They actually look very nice and decent and price isn't bad at all. 1 Share this post Link to post Share on other sites
Carmine A 2046 Posted August 15, 2020 A close Friend, Mark Bryan, has the FF-03. (Maybe you've heard of him around YouTube?) He says about the same thing... Watching it run almost defies LOGIC!! 😲 For a FWD Car, it handles BETTER than most AWD Cars! Share this post Link to post Share on other sites
Nicadraus 6198 Posted August 17, 2020 On 8/16/2020 at 12:54 AM, Carmine A said: A close Friend, Mark Bryan, has the FF-03. (Maybe you've heard of him around YouTube?) He says about the same thing... Watching it run almost defies LOGIC!! 😲 For a FWD Car, it handles BETTER than most AWD Cars! Yup I've seen his videos. 1 Share this post Link to post Share on other sites
Nicadraus 6198 Posted August 17, 2020 So I decided to call this baby... Rally Sport 6 Share this post Link to post Share on other sites
