This is only my second build and I really wanted to try and make a good job of the paint work.Ā Which basically meant changing my mind on colours,Ā digressing over styleĀ and avoiding starting for a few extra weeks but at last it's done. This was a red edition kitĀ so IĀ wanted to use some red, but didn't want to go box art. I painted a few spoon tests andĀ ended up with a full baseĀ coat ofĀ Gun Metal and then masked up for a Metallic Red top half. For the graphics I went with the less is more approach but may add some more later. Apart from the cosmetics It's pretty stock, I just added the CVAs front and rearĀ and the AMPRO transmissionĀ brace. Overall it was a fun build andĀ I'm pretty happy with the results.
Ā
  • Like 11
8 hours ago, SupraChrgd82 said:
Wow! That paint turned outĀ fabulous!
Ā
Don't forget your camera. Ā It's over to the left on a big rock.
Ha good spot :)Ā
On 8/9/2020 at 9:45 PM, Dakratfink said:
Amazing paint !Ā
howĀ do you like the Ampro transmission brace ?Ā
It's pretty perfect, super simple to fit and does exactly what it is supposed to. If i had to complain about anything it would be the heavy shipping cost, but that doesn't take away from the design or use. I would recommend it.
    • IXLR8  »  Clappy75
      Hi Jon,
      In the linked image, I've simply moved the bar forward until it is centered directly over the rear shock tower (approx. 10.72mm) and kept the same height. Ā Is this what you had in mind?
      https://flic.kr/p/2roEkj2
      DougĀ
      Ā
      Ā
      · 0 replies
    • WhteRbt
      Checking out this status thing…  And now with a beautiful avatar! šŸ˜‚
      · 0 replies
      · 0 replies
      Hello
      Hope you are well
      Thank you for your help
      Kind regards
      Jack
      · 0 replies
    • seoondaddy
      Seo-onDaddy - YouTube
      · 0 replies
