dave.723 132 Posted August 5, 2020 Hej Everyone, my monster racer is still slipping and the transmission will soon fall apart. Now I got this chance to get my hands on a A&L tranny. My question are ... will it really fit the monster racer as it actually says for astute ? (I am running universals) will it hold up ? and how long will it last to rebuild the ball diff ? and are spares available to do that ? I am thinking running it on a 3000KV BL or something like a GT tuned. Many thanks David Share this post Link to post Share on other sites
dave.723 132 Posted August 5, 2020 and i forgot to mention that it is the nr. 208 kit. Share this post Link to post Share on other sites
MICHAELs TopForce17 586 Posted August 5, 2020 No experience with a&l make sure you can get spares. Another option is adding the 2018 super astute trans. Check manual for all parts needed. Share this post Link to post Share on other sites
Saito2 6686 Posted August 5, 2020 5 hours ago, dave.723 said: and i forgot to mention that it is the nr. 208 kit. A&L is kind of still around although they are now called "Factory Works" www.factoryworks.com They do list some parts for Lethal Weapon transmissions although the complete Tamiya versions are discontinued. They list the Astute version as kit no.199 and the King Cab/Monster Racer as kit no.198 so there might be some differences between the two. I'd contact them with any question you might have. 1 Share this post Link to post Share on other sites
Frog Jumper 3662 Posted August 5, 2020 Those FactoryWorks people are also cloning vintage JG MFG parts. More power to them I say... Terry 1 Share this post Link to post Share on other sites
jonboy1 2943 Posted August 7, 2020 I can't help with the diff question sorry, but I have bought a chassis kit from Factoryworks and Geoff is a top fella and the quality of the chassis kit is superb. 1 Share this post Link to post Share on other sites
GTodd 1350 Posted August 8, 2020 Just my recommendation, the way to go is the super Astute Rere trans. You can piece it together for less than 100 us. The benefits are: a differential that is bulletproof and can be tuned with differential putty, great selection of gear ratios if you use Tamiya or RC10 associated standard 48 pitch gears, and a slipper clutch. I did this for the Kingcab that I built for my son. Share this post Link to post Share on other sites
kontemax 1725 Posted September 2, 2020 I have this transmission on my King Cab. You must to cut the rear end of the chassis. Other issues are related with the transmission. I needed to shorten the diff cups to not limit the suspensions movement. The part is rough but really strong. When I purchased it there were no alternative, today I would have a different decision. Max 2 Share this post Link to post Share on other sites
jonboy1 2943 Posted September 3, 2020 7 hours ago, kontemax said: I have this transmission on my King Cab. You must to cut the rear end of the chassis. Other issues are related with the transmission. I needed to shorten the diff cups to not limit the suspensions movement. The part is rough but really strong. When I purchased it there were no alternative, today I would have a different decision. Max That's really interesting to know Max, and has answered a question I've had in the back of my head for a while. The KingCab I bought earlier in the year had a section of the rear chassis removed and for the life of me I couldn't work out why they would have done that - now I know why! They must have had an AL Lethal Weapon transmission fitted! Share this post Link to post Share on other sites
kontemax 1725 Posted September 4, 2020 Have a look at here, old and bad pictures, sorry, and you don't see too muck. Another issue of A&L transmission: the motor must turn reverse and no gear reduction inside, due the lack of the iddle gear so with bigger tires you can't have the correct final gear ratio, you are always a little bit too low. As I said I'm not particularly happy of this belt transmission but there was nothing better at the era. If I will come back to the hobby I will replace this transmission with another one. https://www.tamiyaclub.com/showroom_model.asp?cid=52319&id=24 Max 1 Share this post Link to post Share on other sites
kontemax 1725 Posted September 4, 2020 Here another solution I tried for my King Cab. I never realized how bad my picture were. https://www.tamiyaclub.com/showroom_model.asp?cid=4709 Max 1 Share this post Link to post Share on other sites
