It seems with all the expensive Prototyping you guys do - it would HAVE to be cheaper at some point to invest in a GOOD 3D Printer, comparable to what Shapeways uses...
I've heard that THEIRS was over $30,000!! But like every other Technology, it's going to start falling fast.
8 hours ago, ChrisRx718 said:
Glad you decided to keep it, and look forward to seeing what you do with it. As 3D printing evolves do you think the cost of them will come down enough for you to invest? Even the limited things I've designed and had printed at shapeways have struck me how expensive it is! I hate to imagine all the expense you've had with all the prototyping you've done!
The tech is always moving forward, but i can't see me getting a printer anytime soon. The main kicker with shapeways is the 10 bucks delivery so getting little bits alone is uneconomical. Having got some PLA prototypes cheap in the uk, the advantage shapeways has is consistency, accuracy and much stronger materials. Those kind of printers aren't getting cheap anytime soon.
Thing is, i don't tend to use shapeways until i am over 90% sure i have the part correct. I have used cheap pla printing in the uk to prototype the FF03 4GR gearcase, but the quality was poor, and that's from a well set up machine with someone who knows what they are doing. I measure very carefully with good tools, use a pro level 3D modelling software, and i am trained in it's use for my day job, so i can keep the risks/expenditure fairly low. Some parts might seem expensive, but ultimately if i can afford it and i enjoy doing it there is value there. Plus, with things like my TRF buggy transmissions in particular, i have made easily as much money through my store as i have spent on doing new bits. That's the strength of Shapeways; if you do something a few people want you can make a dew bucks and on a small scale like mine i would say its cost neutral.
This actually got me interested in actual machine prices. Turns out a small SLS desktop printer would be about EUR5,000 (about $6,000). Still a lot more than i've spent at Shapeways!!!!
It's at least come down considerably from the last time I looked into it, in 2014...  SHIPPING kills it for me especially.
Western U.S. particularly. Even small stuff from Shapeways has been as much as $15-$20!! 😲😖  Anyone who knows me knows I obviously can't afford THAT.
You're right about SLS and PLA. Proof of concept are the C-Hubs on my 8lb Crawler - and the AmPro Front Double Wishbone Suspension Kit on my Lunchbox. BOTH have taken a lot of abuse and at 7 and 5 years old respectively, both are still going strong!! 👍👍
Have you ever thought of selling, or giving away your 3D Files in "My Mini Factory"?? It seems simpler for the smaller Independent like yourself. And since all you're really doing is basically having your Files Hosted, for a small fee with no Shipping involved...
It would seem that your profit margin would be considerably higher! 👍👍
I WISH I could get my Old Brain to wrap itself around CAD. I just can't seem to get it. I'd do it in a Heartbeat. It might've been able to keep our heads above water here...
Can I have the Link to your Shapeways Store? In case I get even more than I'm planning next year...
I'm planning on a Shopping spree that would make a Teenage Girl jealous!! 😜😂
  • 4 weeks later...
Shapeways and Fibrelyte goodness!
20201007_185149
20201007_185232
So, we have steering arms (pretty much direct replacement for the cracked kit arms), bumper in flexible PA12 material, and mounts for the front and carbon parts. In carbon was have front and rear towers and the rear upper deck.
Firstly steering arms....
20201007_191504
Plastic tie rod and bushings replaced with ball connectors and a spare turnbuckle. The ball cups set at 55.5mm centres same as the kit tie bar.
Next is front tower. I designed shaped and keyed inserts to mount the body posts because they are angled up from the tower.
20201007_193448
The block mounting the tower is angled at 4 deg, same as the front kickup, so the shocks run straight.
All assembled
20201007_195213
At this point it became apparent i got this wrong. Without any offset for their mounting, the camber link mount on the right interferes with the spur cover, and the low, central tower bolt/nut catches on the top cover.
20201008_070705
Onto the rear!
20201008_072257
This mainly a tidied up version of @wtcc5 design, so hat tipto him. It's a carbon top deck to replace the bulky plastic kit part, and i designed a nice 3D printed interface piece for the rear tower attachment, plus a spacer (pictured below) so the plate fits flush with the other top deck.
20201008_074603
And all installed
20201008_074841
You can see i have replaced the screws in the bottom deck that did attavh to the plastic bulkhead with machine screws and nuts.
20201008_080334
For the body mounts, I had to trim the corners off the square lugs to fit, but the went on easily. I didn't release the rear of the kit mount had removeable square inserts too, and they don't fit, so i used some spare CVA pistons as big washers which did the trick.
Everything else just bolts on directly
20201008_080346
Finally, the bumper went on nicely enough but i didn't make it nearly deep enough to protect the front of the chassis.
20201008_081301
I have already damaged and gouged my beautiful Eagle Racing front lower deck, so whilst i will leave this on, it needs changing.
So, probably 50% successful! The rear went together beautifully, the steering arms seem good, and i am really pleased the front body post arrangement work because that was hard to model!
I have redesigned the front tower mount to pull the tower 3mm back, and made the mounting holes to be threaded so there are only screw heads on the front instead of nuts. That should sort all the clearance issues. I have also done a much deeper bumper, this time in black versatile plastic. It will be deep enough to shroud the front of the chassis and protect it by hitting the ground first. Finally, seeing as i was ordering just as small number of parts, i finished off the replacement front arms i have been working on. Again, i will try them in versatile plastic. They are pretty much a direct copy of the ABS kit parts, but with thicker material all round. The c hub pivots on my kit arms are very baggy so i would like to replace them. I also built in 2mm of room for spacers either side of the c hub so i can adjust the wheelbase a little. They should be here by the end of the month. If it all goes together nicely i think there are a couple more tweaks to make on the carbon front tower to make it easier to install the mounting block, so i will do that and give all the designs to Fibre Lyte and put the upgrade kit of parts on my Shapeways store.
Right Nice!! I guess with that much reengineering, a few tweaks are par for the course... But it REALLY looks the business!!! 👌
ANY of this fit the FF-03? I'll HAVE one somehow... maybe rob a BANK!! 😜
Thanks. None of this is FF03 compatible, but you can get aftermarket carbon towers for the 03 easily enough.
Damned you Cy! You made me so envious. I want those CF shock towers, steering set and front shock tower holder.
Do you think it's possible to order for me and ship it here?
I would be happy to once I have a front tower option that works. Like I said in the post, there's some revised parts on the way to get it working as is, but once I have those and I know I have all the clearances I need, I'll update the front tower and mounting design to make the parts simpler and easier to install for anyone else getting them. As soon as I have done that, I'll put the kits up for sale on Shapeways and Fibre-Lyte. I suspect it would be cheapest/easiest for you to order Shapeways kit yourself direct once it's on my store, and give me a shout about the carbon parts so I can order them for you.
Just send me the links. Thanks! :)
I've just started cleaning up an ff01 I got in a job lot and it has a broken rear shock tower, where the top arm attaches, so I'm going to need something to either fix it or replace it with.
How much did the rear shock mount cost from fibre-lyte and can anyone order it from them now? I notice they don't have any ff01 parts listed on their website.
Its not on their list because its my design. I haven't told them they can sell it yet. I guess based on their other shovk towers it would be about £15. I don't want to release it for sale yet until i have the whole thing sorted. I also don't know if it fits with the kit parts. I designed it with the rear upper deck.
Hmm - so I might have to buy the rest of your rear kit too!
Or I could try making a brace out of some frp plate I have here to go over the existing rear shock tower, rather than replace it entirely. I'll have to use longer screws and remove some plastic from the upper arms to about for the extra thickness, or swap them for ball ends.
Seems if you order just versatile plastic and no PA12 material Shapeways tutns around in about a week. Bonus!
20201014_195402
All trimmed, reamed and tapped
20201014_200045
Arms and bumper on first
20201014_203314 20201014_203319
The arms are pretty much right. I forgot to account for the 2mm wheelbase adjustmrnt i added so the e clip shafts came up short. I counterbored the larger pivot lug with a 5.1 drill to let the e clip in on the inboard end, but i am not expecting it to be super robust. I also found that the thicker webs i put on this catch the steering arms on compression a bit. I can trim these to suit, but i have a redesign in mind. In fact, i have two: Firstly a straight repro arm with no adjustment, but trimmed to clear the steering arms, and a second version with the wheelbase adjustment accounting for the e clip with a larger counterbored lug, and also maybe a few mm wider for better suspension. I am running a 7mm thick hex even on my fairly narrow 306 shell. I could definitely add 2-3 to the arm length for use with a thinner hex. The nice thing is that the outcome of these arms is what i wanted; they have almost no slop.
More later.....
Onto the front tower. I had to revise the mounting block to pull the tower back a few mm and that made the access for the mounting screws to the gearcase tricky. It just worked, but I different shape tower and block are needed before I offer them for sale.
20201014_204030 20201014_204026
The new block position worked, because everything clears now, including the camber link ball screws.
20201014_204238
Here's the rear view
20201014_204937
The mounting screws are hard to package and install because you can see I've put the screws holding the tower to the block pretty much in line with them. The revised version has wider mounting points for the top tower screws.
One thing I found is that the body posts are now about 3-4mm higher than they were on the original. I have to drop the body pin by one notch (3.5mm) to get the body height right, so the revised version also needs lower body post mounts. The mounting parts themselves work perfectly though, which is great because they were a ****** to model!
20201015_182754
Because of the taller body posts the shocks mounted on the ends gave too low ride height. I like using this more inboard postion rather than the actual mounts because it gives the shocks slightly better geometry. Anyway, the standard setup for these shocks from the manual is to have a single o ring inside to shorten them, so I stripped the dampers and pulled them out, and now it sits nicely. I just needs a thicker preload clip to take up the slack and add the right amount of preload. The ride height is around 6.5-7 front and rear.
And this is the whole chassis:
20201015_182859
I took it out for a spin before dark and it handles so nicely. The tighter front end is noticeable. It tracks straight and responds really crisply, and there's really good grip. It's lovely! Really pleased with how these parts came out. I will do some more work on them and put them on Shapeways and let Fibrelyte know which files to cut from if someone orders the carbon parts. The current list of things to do is:
Front Tower:
- Reshape shock tower to drop the body post mounts by 3mm, and reshape mounting block to suit.
- New mounting block with wider top mounts to make gearbox screw access easy.
- 15mm spacers for people wishing to use the proper shock mount holes
- Enlarge the motor wire routing hole to a slot to pass both wires through
Steering Arms:
- Shorten the pivot centres 2.5mm all round to give more arm clearance without messing up the leverage ratio of the servo
Front Arms:
- Redo current design to trim back web on trailing edge to clear steering arms. Ditch adjustability and do a straight repro set
- Develop the first design with 2.5mm wider stance, wider shock mountings, retain adjustability with reinforced bosses to suit.
Rear Tower:
- Add some cut outs and a centre hole to mount the antenna mount from the kit
- Spacers for shock mounting (I happened to have some alloy ones spare that were spot on)
- Shaped washers for body posts
Body Posts:
- Design some new body posts to use the touring car standard directly over the rear axle line, and reaching forward from the shock tower to the 'bumper' position so I can swap bodies more easily.
What do you think?
  • Thanks 2
WHAT do I think?? Well done doesn't begin to describe it!  What you're doing almost makes me want to get a FF-01 instead of an 03, just for the well tuned GOODIES! 😊
..... Unless you're planning on tweaking a FF-03 next. 😉
Great work; really doing it some justice!
You know that the original FRP decks stand out like a sore thumb now though? They definitely need carbon fibre-ing!
Looks almost possible to build a continuous upper deck, linking front and rear bulkheads together? Utterly pointless but would be serious bling factor :lol:
It would look nice but i like the original parts.
1 hour ago, wtcc5 said:
Awesome to see you are so active with re-engineering this car! I wish we could race together one day!
Thanks dude! Would be fun to run cars together for sure. Who knows when that might be ok?
Couple of little things. Firstly i manahed to bag a brand new gearcase off ebay. It wasn't cheap, but given i am miles off getting a repro 3d printed case right in CAD and the current unfinished model priced at over $50 on Shapeways, i felt it was ok value. Every hole got tapped for machine screws so hopefully this will last, despite its age.
20201018_184953
Whilst i had it all apart i trimmed the arm flanges with my dremmel to clear the steering
20201018_185019
I also drilled and tapped a hole in the rear tower so i could mount the antenna holder
20201018_184939
I raced on saturday and during practice i gave the FF01 a run, and it was running really nice. Only managed a couple of laps, but it was much morebalanced than the FF03. Now it's cold it seems the FF03 just has no rear grip no matter what i do. The FF01 just drove on its Ride ETS tyres. Granted it was nowhere near as fast (6.4 vs 4.1 gearing will do that), but i was pleasantly surprised how easy it was to handle on track, especially given how relatively softly sprung it is.
I'd be happy with those results. You're reengineering a deep out of production Car - and doing quite well at that!  It was good that you had a FF-03 there for comparison.
I'm spitballing here, but if cold weather is taking the grip out of the rubber Tires, maybe you could try foam?
Thanks. We aren't allowed to run foams and everyone else is running fine on rubber. I think the issue is well used 32 and 34 compound tyres. I have managed to find some 28s, but no one has any sorex 20 or sweep 24 which is what i am going to need if i do any more.
