So some will know about my stop/start attempts at onroad racing (more stop than start) which has led to me spending far more than I needed to on my TA07 Pro, which doesn’t really resemble a Pro anymore.  It still has the shocks.
I bought the car along with a TRF102 to race onroad a few years ago and didn’t really gel with the club, so I only went a handful of times.  I went along to outdoor onroad racing with the same club after a 2 year break and had a great day.  The club has changed with a new committee, and I think the outdoor racing is more relaxed than indoor where they seem to be more serious.  My son had a blast and won the kids class so we’ll definitely be going back.
The TRF102 was always easy to drive (its all relative, they're a handful but the box stock TRF102 holds its own against XRay etc) and the only upgrades have been the wider F103 arms, so I have both options now.  This performed flawlessly all day and I ended up a clear second, with a lap either side of me.
The TA07 has always been the problem child.  It is very flexible out of the box and my knowledge of setup when I started was non-existant.  I have a much better understanding now, and the car has undergone a lot of changes along the way to the point where it is now in a good place.  Easy to drive and clearly not holding me back at all, in the right hands it would be a front runner.
Stock form – a real handful.  I probably didn’t have it set up very well at on the first few outings due to lack of experience.  I ran it indoors a few times with just sway bars and never really got going.  I was always well off the pace.
Upgrades – I bought a series of upgrades for the car, some of which I think are really important, many less so.
Stiffeners – all of them.  I bought the carbon fibre and carbon reinforced plastic ones as well as the extra centre stiffener, all of which made a massive difference.
Alloy suspension blocks – I just have the kit sized ones, but what a huge improvement.  Probably the single biggest thing.  It removed all the slop from the arms which I had been shimming out previously.  Since installing the alloy blocks I haven’t had to touch them again.
Shock towers – the kit ones have a bit of flex, the carbon don’t.  Its on the plastic bulkhead which of course will mean a bit of flex, but these remove 99% of the flex
Servo mount – I’ve heard this is a big improvement but didn’t notice anything.  Looks cool though.  I have the Active Hobby one because I got a deal on a bunch of hopups from someone at the club.
Motor mounts – not sure these make much difference, since they are screwing into a plastic chassis, but they are cheap and blue.
20T pulley – this reduces the IR to 1.85, same as the TRF419 and TA07MS.  Not sure it makes a difference but it was about $2 for the 20T pulley so why not.
I also have the TRF418 swaybar set, and a bunch of springs and shock oils for tuning.
This is how it was when I took it out of its box from the last meet, ages ago.
20200725_130754
I used a shorty pack and that foam block was cut from packaging, transponder mounts on the front bulkhead, and you can still see the sand and grit from its last use.
I had a hankering to build a new touring car but that would just end up sitting next to my TA07 unused, so I bought the Exotek RS7 conversion instead.  Now I just have half a touring car sitting in a box.  This is a traditional double deck touring car layout in carbon fibre.  There are a number of carbon conversion kits available (PSM, RCLabHK, Jazrider) but I’ve always found Exotek to be excellent for my offroad cars so went with the Exotek one.
I bought a few other bits too for it when I bought the RS7 conversion like arms – soft, med and hard arms (but the description was wrong on 54691, you need 2 packs) and then shims, o-rings etc to freshen the whole car up.  I decided against the TRF420 upgrade as it would cost a lot compared to just some new arms.  I also added carbon reinforced A parts for the bulkheads (USD10 total vs USD30 per alloy bulkhead and I’m hoping I get some or all of the benefit).
The issue with 54691 meant I needed a second order because they are the medium arms and the ones I wanted to start with.  Because of Covid shipping is super expensive, so to lessen the blow I also bout the blue steering bits.
20200725_130758
Obviously had to disassemble the Pro since about half of it is still being used.
20200725_133521
Then reassembly on the RS7 chassis
20200725_135606 20200725_142842
Lucky the instructions actually point out that the belt has to go under the steering bridge.
20200725_144549 20200725_145255
Thats an Active Hobby servo mount.  It has worked really well, it has another bit you can add to the top for the TA07 chassis, but works for this one too.
20200725_150819
New motor mount was included with the RS7 kit.  The motor sits lower.  In practice it really just means you use 2 screw holes on the same side of the motor and brushed motors won't work since it doesn't have a screw hole for motor holes that are opposite each other.  You could use the TA07 motor mount though.
20200725_165118
I probably forgot some photos since its jumped ahead to a finished car.  That battery still works, but its being relegated to practice or my son's TT02.
20200725_165148
Fiddly battery mounts, I need to work those out, but will do it when I have the new battery so I can set it for that.
So this is how the car was for the first race meet in ages.  I only used the lower parts of the bulkheads as I ran out of ball connectors and would rather leave the originals in the arms, bulkhead etc in case I reuse them, which is either a bitsa TA07 build or running repairs.
I put a basic setup on it for stock racing and it was all working pretty well.
Another change which has made a big difference is the spec motor, everyone runs a Reds VX1 which are getting on a bit now.  I was running a Speed Passion V3 which is fine for bashing, but up against Trinity Monster Max, R1 Wurks etc I was being passed like I was standing still.  NZRCA adopted a spec motor a few years ago and the club adopted it last year.  I think this is changing next year, if it does the Reds will go in the TRF102 and I’ll get another Surpass V4S or V5R for the TA07.
I didn’t actually finish the final at the race meet, I had a heavy crash in the warmup which resulted in a broken c-hub and eventually a lost screw which was ripped out of the upright.  Its frustrating as it’s a temporary track, so I clipped a piece of track border which had moved from someone hitting the other side of it.  The car was on its roof and then got collected by another car resulting in the battery coming out and me starting from the pits.  About 3mins into the race the screw must have finally fallen out as the car was very clearly pulling to one side, so I stopped at that point.  On closer inspection I realised that the c-hub was broken too, so needed a new upright and c hub.
20200805_132850
This meant another order.  I searched locally and while TT02 parts are easy to get locally, I couldn’t find anywhere in NZ which had any stock of uprights or c hubs.  I’m not sure if my searching is useless, or they just don’t carry parts for the mid-high end Tamiya’s.
Once again shipping was a killer, but I had to go with fedex to ensure I got the stuff in time, so I padded the next order too.
DCJ’s – recent addition to ease the pain of covid shipping costs.  Not yet run.  Also, didn’t notice steering chatter with the universals.
Uprights – soft and hard options
C Hubs – 4deg and 6deg options, hard and soft, but should get more as spares.
Titanium turnbuckle kit (Yeah Racing, cheap and should be good)
Various bits like flanged tube, ball connectors etc
20200805_131454
I know I asked about the best ball connectors, turns out that the cheapest ones were the best afterall!  They were USD2.50 for a pack of 10, the best ones were about USD7.50 for a pack of 5.  I needed 10 just to fit the bulkheads and set up the stiff arms.
20200805_135123
Here showing the new upright, c-hub and DCJ fitted
I have also rebuilt the shocks which I didn't do before the last race meet.  They actually felt pretty good still, and I just ran out of time.  It took over 4 hours to do the RS7 conversion.  The shocks got thoroughly cleaned and new seals etc, but otherwise built just the same as they were which is as per kit with 400CST oil.
There is some headroom in the gearing at the moment, the motor came off cool but my IR temp gun ran out of batteries so I stayed conservative after the 2nd qualifier last meet.  I reckon I have maybe 2 more teeth on the pinion to go, I have pinions though.
I made yet another order, but this one isn’t urgent, I did it now for some spares and it doesn’t matter if I don’t get it for a month or so.  A spare set of 54691 arms, spare c hubs, rear uprights (carbon reinforced, also ordered 2 sets so I have spares) and a bunch of bearings.  I try to keep a stock of bearings and was running low on some, and also thought I should get some 5x10x3 which the DCJ’s require.  I would happily run metal shielded and change them out, but they only had rubber shields so they’ll have to do.  I find that Tamiya bearings last really well unlike other brands so expect them all to last ages, but you never can tell.
So its all ready for the next race meet which is on Sunday, assuming the weather plays nice.
8 hours ago, ThunderDragonCy said:
Great @Jonathon Gillham! Nice to see you get a write up going, and I think it's the first TA07 I've seen on here too.
I've been pretty slack - that was the first 3 posts in one, at this rate I'll be doing another post at christmas!
There are 2 TA07 build threads on here if you're interested in a TA07 Pro build. Effigy did a very detailed one and so did Fujio, but Fujio also detailed his TB01 restoration in the same thread so its not all TA07
Rebuilt the rear diff which has always leaked.  I had just topped it up previously, knowing that I needed to rebuild it properly soon.  I followed the guide on rcracer which will hopefully mean no more leaks despite the thin 2k oil in it.  It suggests using a lot of green slime, where the manual doesn't mention it at all.  I don't have green slime, but I do have XTR o-ring grease which I'm pretty sure is the same thing, so used a lot of that.  Unfortunately I didn't get any pictures as my phone rang so was on my phone which I needed for pictures while I did it.  Used my last 1510 bearings too, luckily some new ones are on a slow boat from Hong Kong.
The car is now all sorted for Sunday, hopefully this rain passes and I get to actually race it.
11 minutes ago, Re-Bugged said:
Good luck for Sunday 👍🏻
Thanks, it may not be the rain thats the problem. We've just had 4 covid cases announced, first in 102 days here, back into lockdown. Could be over by Friday, could be the weekend done as well...
  • Sad 2
Nuts, and we just saw NZ celebrating no new cases for ages on the news here just yesterday. Stay safe mate.
Yes , it's not good . This will stop me getting back to Australia . I have my flights cancelled last month . I have rebooked them
for the 1st sep , but that may get cancelled if this keeps up :( . I have been here since 6 june . ( had too come to NZ sadly )
So the news of 4 cases and another lockdown not too good . Hope it's only 3 days . But i can't see that it will be .
So are you Auckland area ? As i'm not luckily . Was there two weeks ago , seeing a M8 .
Great build .. You may have time to do it if, we all get another lock down :P. ..
2 hours ago, Nicadraus said:
This is a beautiful build @Jonathon Gillham!
Thought you might like it, now we're in lockdown I might try some custom carbon pieces. Won't be anything like yours though!
Yep in Auckland, luckily I can work from home so I'm not too badly affected but this time will be a lot harder than the last one. Where are you staying now?
Why not? All you need is dremel, carbon fiber boards and imagination. :lol:
I'm sure that'll turn out really nice. :)
Waipukurau @  (mums)/ Family house .
Good you can work from home then .  Gee RC is very costly here in NZ WOW !! ...  Only saw one rc shop so far ,
that was in Taupo . Got grasshopper/hornet chassis and B parts tree boomerang . Didn't need them , but just wanted
to buy somthing rc tamiya here :lol: ....
If it wasn't for online shopping it would incredibly expensive!  It wasn't so bad for kits about 9 months ago, prices have gone up heaps since then.  But then some electronics are crazy money here - 10th scale ESC for $500 is just ridiculous.  Then you get the HW1060's for $40 though, which is about the same as they are anywhere.
Hopefully you can stay sane at the family house, I reckon I could manage about a week before needing some time out...
I did two weeks ago , headed to Auckland , stopped in taupo etc . .
Board as heellllllllll , been here since 6 june . NO rc or 3d printing etc . NO money as thats running out . Can't get home ,
as they get cancelled . I'm sure it will be cancelled again and i will have to wait , till 25 oct as that will take me to Perth WA .
Not through Melbourne then perth . But got to go to Auckland to fly out :lol: . I may be stuck here for ever :( ...
MFU in taupo $700 or so . I get them under $500 just , in aus LHS . I almost fell over on the prices here . I would have
got an rc or even a truck to keep my self busy . But not at that price :O .
Hope you can get back soon.
Auckland probably isn't the best place to be right now.
At least you're away from that lunatic named Clive Palmer...
