Probably - but test it first on an off-cut. Depending on how the acrylic is applied, I'd be concerned about solvents not reacting nicely with the polycarb paint.
I've applied Tamiya TS paints to PS Matte Clear used as a primer on lexan - nobody died. But that was small amounts and with an airbrush, not backing quantities from a can.
6 hours ago, Wetman said:
Like a silly git i`ve run out of black, so i was wondering can you use normal auto paint (acrylic) to back polycarb paint?
Acrylic paint will crack off at the first hint of the body flexing
Applied direct to polycarbonate, yes. If applied to a polycarbonate specific paint on polycarbonate, not so much. You might get spidering, but the polycarb paint layer will act a good primer for the acrylic to key in to, so it probably won't break away. Probably good enough for a backing colour that's not really on-show.
Mileage may vary depending on the paint brands and how well they live together. Testing is the key...
