Bennett Ironman 100 Posted August 20, 2020 Whilst looking over my current builds and thinking....how do I run my buggies off one Transmitter ....๐ณ Would make life so much easier...I currently run 2wd and 4wd buggies both using identical receivers...Absima R3FS and CR2s.v2 transmitter ....might sell these..and replace both with a set up I can switch between rides ...is this possible and any recommendations....not got a massive budget and currently wife...is at home ๐ก if you catch my driftย In advance thanksย Share this post Link to post Share on other sites
Biz73 603 Posted August 20, 2020 https://www.ebay.com/itm/Flysky-FS-GT3C-2-4GHz-3-Channel-3CH-Surface-Radio-R-C-RC-Car-Boat-Transmitter-TX/191578239067?epid=1156609914&hash=item2c9af3f05b:g:nnsAAOSwL7VWqydq https://www.ebay.com/itm/5-PCS-Flysky-FS-GR3E-Upgraded-AFHDS-2-4G-3CH-Receiver-for-Car-Boat-RC-FS-GT3C/323788538328?hash=item4b634d01d8:g:O0YAAOSwozpcwYr3 ย 1 Share this post Link to post Share on other sites
markbt73 5290 Posted August 20, 2020 Cheap way: Put velcro on the back of your receiver and swap it between cars as needed. After all, you can only drive one at a time. I've been doing this for many years, ever since receivers stopped having long antenna wires. Expensive way: Some other radio with multiple receivers and multiple model memories that I can't be bothered with, but plenty of others here can help guide you. 1 1 Share this post Link to post Share on other sites
Ray_ve 1031 Posted August 20, 2020 If budget is an issue... I user a cheap 2.4ghz TG3 pistolgrip set from aliexpress. The set is about 20 euro's, extra receivers 4.50 euro's. So alle my running models are ready to go, just pop in a battery. 2 1 Share this post Link to post Share on other sites
Bennett Ironman 100 Posted August 20, 2020 Budget not a massive problem hiding RC purchases from wife is ๐ณ 2 Share this post Link to post Share on other sites
Ray_ve 1031 Posted August 20, 2020 Ah yes, here in the Netherlands we have the option to transfer packages to a pickup point instead of home. That saved me many times.ย 1 Share this post Link to post Share on other sites
MrBlz 21 Posted August 21, 2020 I purchased a Spektrum STX3 from Horizon Hobbyย $45 for the transmitter and one receiver.ย Additional SRX300 receivers are only $15.00 and since I can only run one at a time this was a good solution for me.ย Share this post Link to post Share on other sites
Bennett Ironman 100 Posted August 21, 2020 Problem solved and it's a 'schoolboy' error from me ๐ turns out I can use the single transmitter binded to both my car's ops ๐ 1 Share this post Link to post Share on other sites
