Bennett Ironman
Radio Ga Ga advise please πŸ˜‰
Whilst looking over my current builds and thinking....how do I run my buggies off one Transmitter ....😳 Would make life so much easier...I currently run 2wd and 4wd buggies both using identical receivers...Absima R3FS and CR2s.v2 transmitter ....might sell these..and replace both with a set up I can switch between rides ...is this possible and any recommendations....not got a massive budget and currently wife...is at home 🏑 if you catch my drift
In advance thanksΒ
Cheap way: Put velcro on the back of your receiver and swap it between cars as needed. After all, you can only drive one at a time. I've been doing this for many years, ever since receivers stopped having long antenna wires.
Expensive way: Some other radio with multiple receivers and multiple model memories that I can't be bothered with, but plenty of others here can help guide you.
If budget is an issue...
I user a cheap 2.4ghz TG3 pistolgrip set from aliexpress.
The set is about 20 euro's, extra receivers 4.50 euro's. So alle my running models are ready to go, just pop in a battery.
Ah yes, here in the Netherlands we have the option to transfer packages to a pickup point instead of home. That saved me many times.Β :lol:
I purchased a Spektrum STX3 from Horizon HobbyΒ  $45 for the transmitter and one receiver.Β  Additional SRX300 receivers are only $15.00 and since I can only run one at a time this was a good solution for me.Β
Problem solved and it's a 'schoolboy' error from me πŸ˜† turns out I can use the single transmitter binded to both my car's ops πŸ™„
