Tore a couple of areas of paint removing the window masks. What is the best way to touch up the areas? Is it possible to spray the paint into the cap to make a pool and then brush the areas?
This is possible, another option would be re-mask the window section, not on the paint, then cut a hole in a plastic bag and cover in masking tape, cut a hole out of the tape section for your touch up area, de-tak the tape on your arm or something and mask and re-spray, the bag makes it easier no mask the whole part, there’s no need to press the tape down firmly since you have the local window mask not on the paint. Test the paint adhesion on some scrap if. You’re unsure of the tape. Whether it’s best to try and hand paint instead really depends on which colour you used and how big the area is. Good luck!
