wtcc5 4896 Posted September 4, 2020 Front unit and chassis marriage: Servo and front brace: 1 Share this post Link to post Share on other sites
wtcc5 4896 Posted September 4, 2020 Anti-roll-bar and front body posts: The build result so far: 🥰 3 Share this post Link to post Share on other sites
wtcc5 4896 Posted September 4, 2020 Tires and wheels: Thankfully Tamiya uses both in other cars as well. Tires and front wheels are no problem to get. Rear wheels are a little bit more difficult,but I found a pair in a german shop 😃 Just one thing is strange. The rear wheels are shiny chrome while the front wheels are kind of semi-gloss. Maybe this is the difference between Dyna Blaster and Street Rover wheels. Or maybe new and old edition... Share this post Link to post Share on other sites
wtcc5 4896 Posted September 4, 2020 Final steps: Battery brace and body I took a closer look at the body today and I am unsure what to do. It was colored with a brush. The paintlayers are very thick. Also I think that non-polycarbonate paint was used, because color easily chippes off the body... I am very tempted to remove the old paint with tons of paintkiller and repaint it again. And while I am unsure what to do, I tried your advises regarding the sticker reattachment. And both techniques worked fine. In this case the decals had already collected dirt underneath. After removing this as good as it was possible, it was clear that the glue would never stick on the body again. In those cases I used the super glue method. The result really is satisfying. Thanks again guys! And the car in all its present glory: 5 Share this post Link to post Share on other sites
Collin 1956 Posted September 4, 2020 I would keep the shell as it is, have seen much worse ones. And blue contrast way better with decals then boxart red. About rims, there are indeed differences between old and newer ones, which is the chrome coat. But I cant tell you which is which. About the MDC, you could swap the white plastic bearing for a ballbearing, if you want to. I really like your photo documentation, such a pleasure to see. Top!!! 1 Share this post Link to post Share on other sites
wtcc5 4896 Posted September 4, 2020 Thank you! Cool info again 👍🏻 The old wheels have the semi-gloss finish, at least the originals that came with the truck have. 1 Share this post Link to post Share on other sites
wtcc5 4896 Posted September 10, 2020 Thanks to @Collin and @Tamiyabigstuff I could get some parts in my hands to make this car even more beautiful At first the rear podplate was a little thorn in my eye: Together with it I also replaced the screws with new shiny ones. Of course Tamiya and from the nineties And then this: A new body set for the full shelfqueen mode. More to come 🥰 1 Share this post Link to post Share on other sites
wtcc5 4896 Posted September 16, 2020 There are not many official Hop Ups for the Dyna Blaster. As far as I know only the pink Acto Power (53122), the turnbuckle shaft set (53181) and the sleeved damper set (53125). The shockbodies for the latter are still available in Germany. I bought them and found an offer from @Collin for the fitting V-parts. Fun fact: the piston rods of the TC-01 are the same. The missing N-parts are not really necessary, because they only consist of the ride height clamps (I used the ones of the stock dampers) and the upper spring retainer (I 3d-printed these). A little problematic are the upper damper mounts. I bought the thick o-rings and 6mm balls, but there is no chance to get the knurled nut. I replaced this part with spacers and a press nut. Building these shocks is fun and they look awesome ... and then I found another Dyna Blaster before having done the body of the first one yet 🤣🥰 It is already laying in parts in front of me. The condition is even better than the first one. Awesome ☺️ 1 Share this post Link to post Share on other sites
Collin 1956 Posted September 19, 2020 Sounds all so familier to me... Once you have one they replicate themself. Really a mystery to me. 1 4 Share this post Link to post Share on other sites
wtcc5 4896 Posted October 5, 2020 A lot of time passed since the last post. I rebuild the second Dyna Blaster and again had soo much fun. Especially the gearbox is a real highlight! The condition is a little more used than the first one I rebuild regarding the moving parts. The plastic therefore looks much better with less or no scratches. I found no damaged parts. I added the blue sleeved dampers again, as they are still available and fair priced. @Collin helped a lot with good suggestions and his ton of experience. I wanted to use 3D printed damper mounts, but in the end it failed to function as I wanted, so I used press nuts again. Two brothers: And then I got the wild idea to drive one of these again. Parts are not available, we all know that. With luck you find a whole chassis here or on Ebay. With the thought, that this runner then will become a shelfqueen later, I don't want to risk any part. I chose @Collin path and 3D printed the rear suspension mounts, steering, c-hubs and front bulkhead. The full size Lipo wouldn't fit underneath the esc platform in front of the rear shocktower. I made a cfk brace and a new battery brace to place the battery properly in the chassis. 3 Share this post Link to post Share on other sites
wtcc5 4896 Posted October 5, 2020 Another challenge was the restoration of the used body. My uncle had cut off the front lip as it was maybe damaged a lot. The color partly chipped of everywhere and the stickers got loose in different places. I adressed the latter earlier on. The color and the cutted front really bothered me. As I have two new bodies lying around and just one sticker set, I really wished I could put the old stickers on one of the new bodies with magic... I took a closer look at the old color layers and found places where I could remove the blue color and it seperated from the body, leaving the body underneath in a virgin condition. The thicker the colorlayer was the better I could remove it. The layer on the hood and roof were so thick, that I could pull it off like vinyl film. It still took time and effort, but was much better than the use of paint killer (which nearly had no effect on the blue color... I tried). The result looked nice, too: The yellow and black was connected strong to the lexan so I decided to let is there and just repaint the locations where it chipped of. The black color painting went on nicely, unfortunately the yellow didn't like the Tamiya PS color and wrinkled of the body again leaving the body underneath crystal clear. It was a little mess pulling the wrinkled color off, but still better than paint killer Strangely not everywhere did the yellow come off... Oh well, it worked. For the blue I chose Tamiya brilliant blue instead of the normal blue, as I found it better fitting to the yellow. The last step then was to replace the broken front lip. Again I am a lucky boy. The previous owner of the second Dyna Blaster added a new body that was only trimmed. He praised himself for having cut the body carefully anf precise. He did even better than that. He trimmed the front and sides much lower than the trimming line suggested, leaving perfect formed material for me to use as front lip for the runner body. I colored it yellow and glued it with ShoeGoo to the old body. This repair is nothing for the collector, but repairs the look for the body and you cannot see it if you stay 2 meters away. The overall result is nearly to good to drive 7 Share this post Link to post Share on other sites
Collin 1956 Posted October 5, 2020 @wtcc5 You did a excellent job on the old body. High 5 and hats off. Blue contrasts much better then red to the yellow/orange decals. About the 3D prints, which looks well printet too, which filament did you use? Looks like PETG from the pics. If you really want to run this Dyna, I would consider to remake the D5 bulkhead as well. The little spikes breaks off so easy. 2 Share this post Link to post Share on other sites
wtcc5 4896 Posted October 5, 2020 1 hour ago, Collin said: @wtcc5 You did a excellent job on the old body. High 5 and hats off. Blue contrasts much better then red to the yellow/orange decals. About the 3D prints, which looks well printet too, which filament did you use? Looks like PETG from the pics. If you really want to run this Dyna, I would consider to remake the D5 bulkhead as well. The little spikes breaks off so easy. Thank you! The blue really catches the eye. I was flashed when my uncle showed his car for the first time 25 years ago. I learned a lot about support structures doing these prints and also looked at your parts filament layer orientation to avoid support material and the ugly surfaces it leaves behind. On the pictures, there are for example two versions of the D1 & D2 parts. I printed the D5 part also... just made no pictures... I used the standard (cheap) material PLA, oversized the parts geometry and printed spares, too. Quincy and I are still searching for a nice playground with (fine) sand, no stones, as he wants to run a vintage buggy. I couldn't stand seeing the Dyna Blaster overturn and crashing after a big jump. A golfcourse would be perfect for it "The little spikes breaks off so easy.": I couldn't add material there, just make it wider, but also didn't thought that these were taking so much force Share this post Link to post Share on other sites
Collin 1956 Posted October 5, 2020 Would you post some pics of your prints please? I am cuious... print position is always a compromis. Our parts need strenght in all directions, they have mounts in 2 axis all time. Definitly hard to find best way to print, if you want avoid supports ect... 1 Share this post Link to post Share on other sites
mman2005 443 Posted October 5, 2020 @wtcc5 I agree with @Collin the prints have come out a great quality. Top work! Shell also looks great 👍 1 Share this post Link to post Share on other sites
wtcc5 4896 Posted October 5, 2020 Thanks again! As said, I have no pictures of the actual prints, but can show parts, orientation and print preparation in Rhino. I built the support structures myself, basically just 0.5mm rectangles, that only touch horizontal orientated surfaces and have a space of 1.5mm in between. So nothing special, but I found it better than let Ultimaker Cura do them automatically or define them in Cura. Front bulkhead: Rear suspension mounts: These need no support. I just print them standing. Steering arms: C-Hubs: They have only one little support surface each which doesn't need to be removed. 3 Share this post Link to post Share on other sites
Collin 1956 Posted October 11, 2020 @wtcc5 Ah, you add the supports already in Rhino, right? Great job on the parts. I always get lost in finishing with nice roundings on the edges/corners, which you even dont notice when you print them 1 Share this post Link to post Share on other sites
GTodd 1349 Posted October 11, 2020 On 10/5/2020 at 12:30 PM, wtcc5 said: Thanks again! As said, I have no pictures of the actual prints, but can show parts, orientation and print preparation in Rhino. I built the support structures myself, basically just 0.5mm rectangles, that only touch horizontal orientated surfaces and have a space of 1.5mm in between. So nothing special, but I found it better than let Ultimaker Cura do them automatically or define them in Cura. Front bulkhead: Rear suspension mounts: These need no support. I just print them standing. Steering arms: C-Hubs: They have only one little support surface each which doesn't need to be removed. How do.i order these? Share this post Link to post Share on other sites
wtcc5 4896 Posted October 16, 2020 On 10/12/2020 at 1:39 AM, GTodd said: How do.i order these? Collin sells his stuff on Ebay and Shapeways already. If you want my parts and are in Europe I could put them on Shapeways or print them FDM. Contact me via PN please if that is the case. Share this post Link to post Share on other sites
Charles M 135 Posted February 10, 2021 Question about a Dyna Blaster lover : ( Box Art ) The body normally is paint into PS6 Yellow and PS15 Red Mettalic. We are agreed, that fading stickers are from Yellow to Orange. ( not trying to fade from PS-6 to PS15 ) That a question due to my management to replicate the Dyna Blaster bodyshell on truck bodyshell ( from Stadium Blitzer/Rock Socker ). I want to make the fading stickers with some masks, and i need to know from which color to which color. Thanks in advance. Cheers Charles Share this post Link to post Share on other sites
wtcc5 4896 Posted February 15, 2021 I am not 100% sure what you mean... Do you mean which colors the sticker blend from one end to the other? If so then: From yellow (PS-6) in front to flourescent red (PS-20). Share this post Link to post Share on other sites
wtcc5 4896 Posted February 24, 2021 Today arrived another gem for the shelfqueen Blaster: I searched for a long time, but finally found a fair priced new one. The seller was really nice and as we know each other from Fb Tamiya groups it came down to a swap and a deal (NIB black Sport Tuned plus money for Pink Acto Power) that made it even more attractive for both of us. Of course I couldn’t wait to add it: Now I am only after the turnbuckle set 53181. But that seems to be even more rare than a Dyna Blaster itself... As I haven’t done the body yet, the new motor motivates me to do it soon. The difficult decision is the main color. I bought the red that Tamiya suggested, but it is no bright nice color. So I am still unsure. A dark silver or grey metallic would look good, too. Or just do the stickers on a transparent body... 4 Share this post Link to post Share on other sites
Charles M 135 Posted February 24, 2021 That a great stuff to put a pink motor into your Dyna Blaster. Firstly, when i'm searching some livery idea for my Dyna Blaster, that be great to be close to my Dyna Storm, and your first bodyshell was close to it. But finally, i'm sure that Dyna Blatser need to be BoxArt to keep is value. But you can order another Bodyshell as stadium truck to make runner bodyshell with other variation of the original livery. What do you plane for this model ? Queen Shelf or Runner ? 1 Share this post Link to post Share on other sites
Charles M 135 Posted February 24, 2021 We are agree about the PS15 color, that not suit to this model. My Dyna Blaster have great color with Pink Fluo and PS16 Mettalic Blue. 1 Share this post Link to post Share on other sites
wtcc5 4896 Posted February 24, 2021 @Charles M This is my shelfqueen. Yeah, the value of boxart should not be underestimated. 1 Share this post Link to post Share on other sites
