esmuz
Ultima pro tires
Hi, I am looking for any tires fitting the ultima pro rims.
Actually I am trying to find something more like the Ultima re-re ribbed ones.
Are the Ultima re-re rims the same as the ones for the ultima pro? What are the specs to look for?
Any suggestions?
Thanks!
Not sure if these would work with what you had in mind, but I used these on my Ultima Pro:
https://www.amainhobbies.com/schumacher-mini-spike-2.0-front-2wd-buggy-tire-2-yellow-schu6850/p701654?v=697591
These should work as well:
https://www.amainhobbies.com/schumacher-slim-rib-spike-2.0-front-2wd-buggy-tire-2-yellow-schu6847/p701642?v=697588
They should both fit the original 50mm rims.
Wow, these look really nice..
Do you think thsese would fit too? I know the Grassopper spikes rear tires fit on classic OT66, maybe front ones will fit too?
https://www.rcmart.com/tamiya-grasshopper-ii-front-rubber-tire-2-pcs-black-19805182-00081341
Sorry, I'm not too sure about that. I don't have a GHII and also couldn't find the specs on those tires.
the original ultima wheels are 1.9 diameter. frog/hornet tires are way to tight.
the axles are 4mm so you can change the fronts to any rim just by fitting a bearing with an inner diameter off 4mm or change the front axle to 5mm with a CRP kit on ebay.
