Avante2001R 293 Posted September 8, 2020 Personally if you want to race get a Cat L1 Evo. Those cars are hard to beat and spares are easy to get. Schumacher is a UK company and their spares supply is much better than Tamiya. Buy the 503 is you want to do some light running for fun and then have for display as they are collectibles. Share this post Link to post Share on other sites
FC5687 8 Posted September 9, 2020 Actually my friend us seeking belt drive 4WD from either Tamiya or Schumacher. I have sent him a link of this thread. Let him make a decision but I have looked into both 503 and db01rrr, personally I prefer rrr with hop up parts as it looks more secure if come to "dirt running" based on the transmission coverage for protection. Me has no interested in belt drive 4WD. I have top force for years as shaft drive is my favourite type of transmission for 4WD. If I buy a new 4WD, probably either a Yokomo or Associated shaft drive 4WD. Share this post Link to post Share on other sites
FC5687 8 Posted September 9, 2020 18 hours ago, Howards said: Yep. 503 specific stuff like chassis and bulkheads will be very hard to get hold of. DB01 stuff is still relatively available. From reading around, the DB01 cars were more raceable for parts availability and cost reasons at the time anyway, and their performance was good enough so that you didn't have to buy a TRF car. Hence they did the RR and RRR versions. Regarding 503 and DB01RRR, are they sharing same transmission but different chassis arrangement? I guess both would be surpassed the CAT XLS even with procat transmission upgrade . It draws my attention about the carbon reinforced chassis for DB01, looks like ABS, so what is it? Share this post Link to post Share on other sites
Avante2001R 293 Posted September 9, 2020 2 minutes ago, FC5687 said: Regarding 503 and DB01RRR, are they sharing same transmission but different chassis arrangement? I guess both would be surpassed the CAT XLS even with procat transmission upgrade . It draws my attention about the carbon reinforced chassis for DB01, looks like ABS, so what is it? I don’t think a 34 year old Cat XLS would surpass the performance of a DB01 or 503. Share this post Link to post Share on other sites
Howards 254 Posted September 9, 2020 28 minutes ago, FC5687 said: Regarding 503 and DB01RRR, are they sharing same transmission but different chassis arrangement? I guess both would be surpassed the CAT XLS even with procat transmission upgrade . It draws my attention about the carbon reinforced chassis for DB01, looks like ABS, so what is it? They share some parts - differentials, tensioners, additional tensioners in the motor mount, pulleys, slipper clutch parts, spur gears. Key difference for transmission is that in the DB01\RRR the motor is mid mounted so the belts are equal length, whereas the 503 has a forward motor, so the belts are different lengths. The 503 only has one pulley for two belts, whereas the DB01 has two separate pulleys next to each other. Thinking about the rest of the car, I think they also share wishbones, hub carriers, hubs, UJs - but not entirely sure, might be small differences you can't see from the manual. They don't share any structural parts as far as I know, suspension blocks and mounts, gearbox housing, that kind of thing. DB01 chassis is glass enforced injection modelled plastic. It is not the standard shiny Tamiya stuff. It's very, very hard, heavy and very very stiff. The wishbones and most other parts are made from the same stuff. They also do a composite enforced version that is stiffer. CAT XLS is very outdated - whilst good for its time the 503 and DB01 will be stronger, more stable, more nimble, easier to work on. They had 20 years to evolve! Share this post Link to post Share on other sites
FC5687 8 Posted September 9, 2020 58 minutes ago, Avante2001R said: I don’t think a 34 year old Cat XLS would surpass the performance of a DB01 or 503. exaxtly!! Even i know nothing about both 503 and DB01RRR But two of my friends bot agree for that. They are big fans of CAT XLS Share this post Link to post Share on other sites
FC5687 8 Posted September 9, 2020 41 minutes ago, Howards said: They share some parts - differentials, tensioners, additional tensioners in the motor mount, pulleys, slipper clutch parts, spur gears. Key difference for transmission is that in the DB01\RRR the motor is mid mounted so the belts are equal length, whereas the 503 has a forward motor, so the belts are different lengths. The 503 only has one pulley for two belts, whereas the DB01 has two separate pulleys next to each other. Thinking about the rest of the car, I think they also share wishbones, hub carriers, hubs, UJs - but not entirely sure, might be small differences you can't see from the manual. They don't share any structural parts as far as I know, suspension blocks and mounts, gearbox housing, that kind of thing. DB01 chassis is glass enforced injection modelled plastic. It is not the standard shiny Tamiya stuff. It's very, very hard, heavy and very very stiff. The wishbones and most other parts are made from the same stuff. They also do a composite enforced version that is stiffer. CAT XLS is very outdated - whilst good for its time the 503 and DB01 will be stronger, more stable, more nimble, easier to work on. They had 20 years to evolve! Thanks again for the Inputs!! I guess the DB01rrr is better overall IMHO. So why the 503 existed I wonder Any hop ups for DB01RRR? I have built the Schumacher XL thirty some years ago for a fellow, the universal drive shaft is unique. I know none of L1 Evo. Is it very good? Share this post Link to post Share on other sites
Avante2001R 293 Posted September 9, 2020 7 minutes ago, FC5687 said: exaxtly!! Even i know nothing about both 503 and DB01RRR But two of my friends bot agree for that. They are big fans of CAT XLS If you are looking to buy a TRF car I do have a 501x for sale in the for sale section of this forum. Share this post Link to post Share on other sites
FC5687 8 Posted September 9, 2020 22 minutes ago, Avante2001R said: If you are looking to buy a TRF car I do have a 501x for sale in the for sale section of this forum. I will forward the info to my friend. Sorry my friend is a Chinese fellow and not very good in English written. Thanks anyway! Share this post Link to post Share on other sites
Howards 254 Posted September 9, 2020 3 hours ago, FC5687 said: I guess the DB01rrr is better overall IMHO. So why the 503 existed I wonder DB01 straddled the period where stick pack NIMH were still a thing and the move to lipo and then shortie format lipo. Basically the chassis layout wasn't great for lightweight batteries. The 503 was designed from the off to have lightweight straddle lipo batteries so will be better balanced with contemporary power options. Hence forward motor location etc. There should have been another 'D' series buggy that would have consumerised this layout in the same way the DB01 consumerised the 511 and 501 layouts but that never happened and Tamiya abandoned buggy racing. Share this post Link to post Share on other sites
FC5687 8 Posted September 9, 2020 Now it makes more sense. My friend just I fired me that he has a hard time to get the RRR. Most shop are "sold out" Share this post Link to post Share on other sites
Avante2001R 293 Posted September 9, 2020 1 hour ago, FC5687 said: Now it makes more sense. My friend just I fired me that he has a hard time to get the RRR. Most shop are "sold out" Those cars are hard to find now. Share this post Link to post Share on other sites
Finnsllc 586 Posted September 11, 2020 @FC5687 where are you finding a db-01 rrr? thats a unicorn from tamiya. whats the point of this converstion? youre not picking up an rrr Share this post Link to post Share on other sites
FC5687 8 Posted September 11, 2020 2 hours ago, Finnsllc said: @FC5687 where are you finding a db-01 rrr? thats a unicorn from tamiya. whats the point of this converstion? youre not picking up an rrr Very easy these days. Google search for "Tamiya db01RRR kit". And you can see the pricing and stock status of this particular one offered by fair amounts of RC online shops, and which is our of stock or sold out Share this post Link to post Share on other sites
Finnsllc 586 Posted September 15, 2020 On 9/11/2020 at 2:33 AM, FC5687 said: Very easy these days. Google search for "Tamiya db01RRR kit". And you can see the pricing and stock status of this particular one offered by fair amounts of RC online shops, and which is our of stock or sold out very easy?i just did what you sugested. nothing in stock anywhere? provide a solid instock link please Share this post Link to post Share on other sites
FC5687 8 Posted September 16, 2020 8 hours ago, Finnsllc said: very easy?i just did what you sugested. nothing in stock anywhere? provide a solid instock link please It shows up several online shop with price and status when we Google search just what I said. Well .... Should I responsible to any updated and removal of those online stores Share this post Link to post Share on other sites
Avante2001R 293 Posted September 16, 2020 Why has this thread turned into back and forth bickering??? 1 1 Share this post Link to post Share on other sites
FC5687 8 Posted September 16, 2020 1 hour ago, Avante2001R said: Why has this thread turned into back and forth bickering??? Yes sir. Sure I hear you. Share this post Link to post Share on other sites
