Nicadraus 6131 Posted September 8, 2020 I was contemplating on what light crawler to get but I always like the CFX. I didn't want a full size 300-313 crawler because I just want something that I can drive side by side with the CC-01 with my daughter. Fortunately, my friend handed me this new (assembled/built and displayed only) CFX. It also comes with a painted body, a rear steel drive shaft, two sets of bead-lock wheels (wide and narrow) and two sets of tires. I plan on upgrading it. So far some parts have already arrived. Aluminum dampers 80mm YR aluminum suspension links for 242mm Aluminum shock towers 25kg SPT servo Aluminum srevo mount with carbon fiber plate (I also used the same for my XV-01) Still upgrading the front and rear bumper mounts to aluminum, steel drive shafts, metal steering links, and full ball sealed bearings. Will also install Hobbywing 1080 ESC and a full light kit with extra roof light bar. I don't want to rush the build but the parts and accessories just make me excited. 8 Share this post Link to post Share on other sites
ChrisRx718 4464 Posted September 8, 2020 Really like these, wouls like your thoughts on the build quality. I've got some of those shocks, they're quite leaky also have issued with the spring retainer between the top and bottom springs 'binding on the lower part of the damper cylinder. They're ok for the money but not a patch on boggo Tamiya CVAs... Share this post Link to post Share on other sites
Nicadraus 6131 Posted September 9, 2020 3 hours ago, ChrisRx718 said: Really like these, wouls like your thoughts on the build quality. I've got some of those shocks, they're quite leaky also have issued with the spring retainer between the top and bottom springs 'binding on the lower part of the damper cylinder. They're ok for the money but not a patch on boggo Tamiya CVAs... Got the same brand of shocks? I guess I'll have to experiment on how to fix that issue. But I also ordered another set of 70mm shocks to see which one will perform better. I just plan on changing the shaft end to extend it to 80mm. Share this post Link to post Share on other sites
Carmine A 2046 Posted September 11, 2020 I still think this is a better alternative to the CC-02... Great score!! I am going to have one at some point. 2 Share this post Link to post Share on other sites
Nicadraus 6131 Posted September 11, 2020 13 hours ago, Carmine A said: I still think this is a better alternative to the CC-02... Great score!! I am going to have one at some point. Definitely a better choice than the CC-02 in terms of money value and build too. Tamiya makes our wallets bleed. 1 Share this post Link to post Share on other sites
Nicadraus 6131 Posted September 11, 2020 New parts came in today. Still deciding whether to go full bearings on this kit or not. I'm concerned about the bearing if or when they get wet during trailing. Although the CC-01 is full balled. 2 Share this post Link to post Share on other sites
Carmine A 2046 Posted September 11, 2020 Definitely full balled!! And unless you plan to go longer, MST Shocks are top notch! Their Driveshafts, even the upgrade ones, are questionable.... Share this post Link to post Share on other sites
Nicadraus 6131 Posted September 12, 2020 So far here's what I have done today... Replaced the center drive shafts with steel Replaced plastic suspension links with YR aluminum for 242mm (50mm lower, 40mm upper) New 80mm shocks. This is actually a generic shocks for 1:14 scale buggy. The length is exact and the springs are perfect. I just replaced the piston with YR 3-holes and the YR o-rings too. Replaced the plastic shock mounts with aluminum Replaced servo mounts to aluminum Fully balled (rubber sealed bearings to follow) Here she is currently... Together with the CC-01 CT 5 1 Share this post Link to post Share on other sites
Carmine A 2046 Posted September 12, 2020 I'd say that what you've done today, is be DONE! Looks SWEET!! 1 Share this post Link to post Share on other sites
Nicadraus 6131 Posted September 12, 2020 1 hour ago, Carmine A said: I'd say that what you've done today, is be DONE! Looks SWEET!! Thank you bro! 1 Share this post Link to post Share on other sites
Nicadraus 6131 Posted September 18, 2020 While waiting for the HW 180 ESC and AFRC-RXS482 receiver, I installed a CF battery tray and re-arranged the layout making it longitudinal. I also cut and fitted side trays for the electronics. Installed an RX box and wrapped the servo wires with braided sleeve. 2 1 Share this post Link to post Share on other sites
Carmine A 2046 Posted September 18, 2020 My Landfreeder Body is absolutely BEGGING for one of those Chassis!! 😁 Is the CF Battery Tray much lighter than the Stock one? Share this post Link to post Share on other sites
Nicadraus 6131 Posted September 18, 2020 4 hours ago, Carmine A said: My Landfreeder Body is absolutely BEGGING for one of those Chassis!! 😁 Is the CF Battery Tray much lighter than the Stock one? Yes it's very light but I didn't remove the stock metal battery plate. That's where I I installed the carbon fiber battery tray. 1 Share this post Link to post Share on other sites
schlabinski 250 Posted September 18, 2020 What receiver box is that? I've been looking for a really simple generic looking one, and that fits the bill. Share this post Link to post Share on other sites
Nicadraus 6131 Posted September 19, 2020 4 hours ago, schlabinski said: What receiver box is that? I've been looking for a really simple generic looking one, and that fits the bill. It's a Tamiya receiver box. I just covered the engraved label. There are a lot of nicer generic boxes too online. 1 Share this post Link to post Share on other sites
Carmine A 2046 Posted September 19, 2020 6 hours ago, Nicadraus said: It's a Tamiya receiver box. I just covered the engraved label. There are a lot of nicer generic boxes too online. Is that the TT-02 Reciever Box? Looks familiar. 1 Share this post Link to post Share on other sites
Nicadraus 6131 Posted September 19, 2020 3 hours ago, Carmine A said: Is that the TT-02 Reciever Box? Looks familiar. Yes it is. 1 Share this post Link to post Share on other sites
schlabinski 250 Posted September 19, 2020 Excellent, thank you. I thought it had that familiar Tamiya plastic shine, but was thrown off by the absence of the label. Nice work! 2 Share this post Link to post Share on other sites
Nicadraus 6131 Posted September 28, 2020 These arrived today... This roof rack is just beautiful! Installed the light bar 4 Share this post Link to post Share on other sites
Carmine A 2046 Posted September 28, 2020 QUITE an impressive bit of Kit! 👍👍 You've probably got the most impressive Brushed ESC on the Market right now as well!!! Really nice Roof Rack, but you've really got me jonesing for a MST CFX Chassis or three!! 😊 Maybe someday. 1 Share this post Link to post Share on other sites
Nicadraus 6131 Posted September 29, 2020 Test fit... 1 1 Share this post Link to post Share on other sites
Nicadraus 6131 Posted October 2, 2020 Side trays and 3D printed fenders arrived this morning. Installed them right away as soon as I got back home. Too much excitement. Haha! 2 Share this post Link to post Share on other sites
Carmine A 2046 Posted October 2, 2020 ha Ha!! Nice! 😊💯 To me, inner Wheelwells are a must, along with an even simple Interior. Those are nicely done. 1 Share this post Link to post Share on other sites
Nicadraus 6131 Posted October 3, 2020 Installed the electronics today and she's finally a runner. Shortened the motor and battery wires, installed braided sleeves and bullet connectors. Soldered female bullet to the motor This AFRC Sanwa compatible receiver works great! Testing... Love how this little beauty turned out. But still waiting for few more parts. Steel center drive shaft, aluminum steering links, steel pivot balls for suspension links, aluminum center skid plate, etc 2 Share this post Link to post Share on other sites
Nicadraus 6131 Posted October 3, 2020 More pics... With the CC-01 CT and CNC Crawler (SCX10 platform). 3 Share this post Link to post Share on other sites
