Quinster 38 Posted September 13, 2020 I’ve just finished building my Blackfoot rerelease. I thought everything was fine but then noticed a slight delay on the steering when turning left and right (on a stand). Sometimes it locked hard left right. I had bought two additional receivers for the flysky and put a new one on the BF. It’s responsive but just a little glitchy, acceleration and reverse are fine. Has anyone else had a similar problem or got any ideas as to what this could be? I thought about putting the stick kit servo saver on to see if that make a difference. I’d like to keep the kimbrough on though if possible. This is the first time buying additional receivers - rather than a kit. I thought that may have been the issue. If anyone has any ideas that would be great. Cheers, Mark Share this post Link to post Share on other sites
Frog Jumper 3661 Posted September 13, 2020 Swap out the receivers and test. Follow up if needed with a servo swap out. Aftrr that, I don’t know... Terry 1 Share this post Link to post Share on other sites
Frog Jumper 3661 Posted September 13, 2020 as for getting stuck hard right/left, you may have to adjust the end points in your steering. You can do this with the Tx. I did it with my FlySky. It’s in the manual... 1 Share this post Link to post Share on other sites
Quinster 38 Posted September 13, 2020 Thanks guys. I’ll swap out the receiver and test again. I think I did muck about with the end points they seemed ok. I’ll see where I get to with the receiver as it was a two pack I bought. Cheers 1 Share this post Link to post Share on other sites
