Quinster
Blackfoot and Flysky GT3C
I’ve just finished building my Blackfoot rerelease. I thought everything was fine but then noticed a slight delay on the steering when turning left and right (on a stand).  Sometimes it locked hard left right.  I had bought two additional receivers for the flysky and put a new one on the BF.
It’s responsive but just a little glitchy, acceleration and reverse are fine.
Has anyone else had a similar problem or got any ideas as to what this could be?  I thought about putting the stick kit servo saver on to see if that make a difference.  I’d like to keep the kimbrough on though if possible.
This is the first time buying additional receivers - rather than a kit.  I thought that may have been the issue.
If anyone has any ideas that would be great.
Cheers,
Mark
Swap out the receivers and test.
Follow up if needed with a servo swap out.
Aftrr that, I don’t know...
Terry
as for getting stuck hard right/left, you may have to adjust the end points in your steering. You can do this with the Tx. I did it with my FlySky. It’s in the manual...
Thanks guys.  I’ll swap out the receiver and test again. I think I did muck about with the end points they seemed ok.  I’ll see where I get to with the receiver as it was a two pack I bought.  Cheers
