Price_of_cider 7 Posted September 14, 2020 Hi all, im looking to sell or swap a Tamiya midnight pumpkin QD. It is working although it seems a bit slow so might benefit from a new motor? i have the original box (if a little moth eaten) and all radio gear is working (red band 2). ideally I’m looking for a standard hobby grade pumpkin/ lunchbox/ monster beetle but all offers considered for both buy or swap. many thanks Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted September 14, 2020 Put a brushless motor in it, they are great little trucks. Share this post Link to post Share on other sites
Price_of_cider 7 Posted September 14, 2020 4 minutes ago, wolfdogstinkus said: Put a brushless motor in it, they are great little trucks. I like the look of that actually - is there a brushless motor that will drop straight in? Or is it likely I’ll need to do some chopping about? cheers Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted September 14, 2020 You may have to drill 2 small holes in the motor plate to bolt on the new motor. It's been years since I did the monster beetle, which is the same chassis as yours but it's an easy conversion to do. Any 1/18th scale motor should fit. 2030 can size, up to a 2435 should fit easy enough. I believe this was a 2030 can size. 18turn EZRUN motor 1 Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted September 14, 2020 This thread may help? Actually I think I do have a thread on the monster beetle as well. Somewhere. 1 Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted September 14, 2020 Try reading this... 1 Share this post Link to post Share on other sites
Price_of_cider 7 Posted September 15, 2020 22 hours ago, wolfdogstinkus said: Try reading this... This is great! so I’m not particularly skilled in these areas but relatively speaking (and with some help from the old man!) this looks fairly simple to achieve? if you were going to write me a shopping list of parts I would need to achieve this - how would it look?!! (If you get a minute and don’t mind!) thanks matt Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted September 15, 2020 1/10 scale servo <£10 ish 1/18th scale brushless combo <£20 Gool RC do a 2435 can/ combo esc for £20ish Radio and receiver,... Flysky GT2= £20 ish. Small 2s lipo, maybe around 2200mah? £10? Yes it adds up but all equipment can be reused in a different car, and at least you know what you are getting into before you start.. You may also need M3 threaded rod, 5mm adjusters and a hi-torque servo saver for the steering. Any questions, give me a shout, I'm on here regularly. Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted September 15, 2020 Any servo saver will do, but the Tamiya Hi-torque one comes with the brass balls that you need for the steering rods. 1 Share this post Link to post Share on other sites
Price_of_cider 7 Posted September 15, 2020 4 hours ago, wolfdogstinkus said: 1/10 scale servo <£10 ish 1/18th scale brushless combo <£20 Gool RC do a 2435 can/ combo esc for £20ish Radio and receiver,... Flysky GT2= £20 ish. Small 2s lipo, maybe around 2200mah? £10? Yes it adds up but all equipment can be reused in a different car, and at least you know what you are getting into before you start.. You may also need M3 threaded rod, 5mm adjusters and a hi-torque servo saver for the steering. Any questions, give me a shout, I'm on here regularly. Perfect!!! thanks for this - I feel a project coming on!!! Matt Share this post Link to post Share on other sites
Price_of_cider 7 Posted September 15, 2020 1 hour ago, wolfdogstinkus said: Any servo saver will do, but the Tamiya Hi-torque one comes with the brass balls that you need for the steering rods. Oh and where is the place to get all of these parts? Ebay? Share this post Link to post Share on other sites
TurnipJF 9192 Posted September 15, 2020 Converting a QD to use hobby-grade electronics is a worthwhile project for an adult modeller looking for something different, and can be very satisfying, but if the end goal is to get a tough and capable runner for a youngster, you might be better off with your original plan to sell the QD and get a hobby-grade Pumpkin. While the QD models are quite tough and capable, their smaller size means that they aren't as good offroad as their larger non-QD brethren, and spare parts/hop-ups are easier to find for the hobby-grade models too. 2 Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted September 16, 2020 Turnips right. The cost to upgrade the qd will be similar to upgrading a 1/10 scale, but the motor is the only bit you couldn't reuse in a bigger car. You could even buy a 1/10 scale esc and a 1/18th motor so that the esc could be used later for another project. Or leave the brushed motor in and just change the Esc (1/10 scale brushed for original motor) Radio and receiver Servo Servo saver and steering parts. Ebay should have everything you need. You will keep the original speed but gain reliability Or run the original motor on 3s lipo for extra boost to the original motor. You could get between £<40-80 if you sold it how it is just now. Let us know what you plan to do.. Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted September 16, 2020 I will add that I did this conversion on the monster beetle, probably 10 years ago, I wasn't using Lipo back then so in the video, it was still using an old 7.2volt Ni-mh battery. Lipo is lighter and provide more torque/punch Yours does look too nice to destroy. If you have the original box, I would probably sell it, but the choice is yours. Another option would be the GF01 trail monster beetle kit which uses the qd monster beetle body which would mean that your pumpkin body will fit a modern chassis. You could sell the qd chassis on its own and still fetch a decent price. Share this post Link to post Share on other sites
KEV THE REV 2319 Posted September 16, 2020 Or maybe a QD like this ? Lunchbox gearbox and modern steering servo / ESC / NiMh battery shoe-horned in 1 Share this post Link to post Share on other sites
Price_of_cider 7 Posted September 16, 2020 37 minutes ago, KEV THE REV said: Or maybe a QD like this ? Lunchbox gearbox and modern steering servo / ESC / NiMh battery shoe-horned in 😍😍😍 Share this post Link to post Share on other sites
Price_of_cider 7 Posted October 9, 2020 On 9/16/2020 at 11:50 AM, KEV THE REV said: Or maybe a QD like this ? Lunchbox gearbox and modern steering servo / ESC / NiMh battery shoe-horned in So a big lunchbox gearbox? what type/size motor? cheers Share this post Link to post Share on other sites
KEV THE REV 2319 Posted October 9, 2020 13 minutes ago, Price_of_cider said: So a big lunchbox gearbox? what type/size motor? cheers Yep . full rear axles / gearbox from a LB with a Reedy 540 motor Share this post Link to post Share on other sites
Price_of_cider 7 Posted October 10, 2020 On 9/15/2020 at 1:29 PM, wolfdogstinkus said: 1/10 scale servo <£10 ish 1/18th scale brushless combo <£20 Gool RC do a 2435 can/ combo esc for £20ish Radio and receiver,... Flysky GT2= £20 ish. Small 2s lipo, maybe around 2200mah? £10? Yes it adds up but all equipment can be reused in a different car, and at least you know what you are getting into before you start.. You may also need M3 threaded rod, 5mm adjusters and a hi-torque servo saver for the steering. Any questions, give me a shout, I'm on here regularly. Hi!! so I’m finally having a go at this! I have just purchased the servo, radio gear, battery and the motor/esc combo. What does a servo saver do in broad terms and what do I need the M3 rod for? i realise I sound a bit of a numpty - this is largely because I am so I appreciate your help! 😂 cheers matt Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted October 11, 2020 You have to make a rod to connect the wheel to the steering servo. I use M3 threaded rod, Tamiya 5mm adjusters and 5mm brass balls ends. The saver is a plastic horn with a spring that protects the servo from breaking when a wheel suffers an impact. There will be better pictures in my brushless thunder dragon thread which will hopefully explain better. Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted October 11, 2020 Here's the wheel end of the steering assembly Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted October 11, 2020 This shows the servo horns and servo. The monster beetle is slightly different but it's the same principle. I used a standard Tamiya servo saver but if you buy the hi torque servo saver, it includes a lot of the hardware needed to connect the threatened rod to the wheels. Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted October 11, 2020 Then you squeeze an old phone in there to give you the top speed. Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted October 11, 2020 Showing 48mph But I do have a 44mph recorded without crashing. Share this post Link to post Share on other sites
Price_of_cider 7 Posted October 11, 2020 3 hours ago, wolfdogstinkus said: Showing 48mph But I do have a 44mph recorded without crashing. Hahaha that’s brilliant!! thanks for all your help on this - it really is much appreciated. Right.... I’m off to buy a servo saver! Share this post Link to post Share on other sites
