novaris
Which differentials to get for the tc-01?
I was watching some youtube videos of the build and 1 video stood out "trf tc-01"
They used a number of expensive parts like
54543TB04 Gear Different Aluminum Cup Joint
54533Gear Differential Cross Shaft for TB04
54540Steel Bevel Gears For TB04 Gear Differential
42324TB05 40T Aluminum Differential Housing Set
54593TB04 Carbon Reinforced G Parts
then  the manual offered a few other options,
54522Tamiya Aluminum Front Direct Coupling For TB04 TB Evo.6
54592Tamiya Aluminum Front Direct Coupling For TB04 TB Evo.6
54522 ball diff set.
54521 front one-way set
and stock diffs
I have no idea what to use for the tc-01, any advice?
Personally I would just go for 54543 TB04 Gear Different Aluminum Cup Joint, and universals.  All of the other diff parts are just extra weight. The only other parts I would consider are the 54533 Gear Differential Cross Shaft, but only if you are going to run a high turn motor. If running anything 13.5 or higher I would stay with plastic. Mine will be wither 21.5 or 17.5
