Sign in to follow this
Cephas
WANTED: Bigwig front yellow cva shocks
Hi
was wondering if anyone had some yellow cva shocks from the Bigwig, I think they are 80mm.
it is for a boomerang to bigwig front end conversion, wanted to keep the same look as the rear.
thanks
Many thanks, very much appreciated
I think these are the right ones - the shock body is about 65mm long including the top mounting eye.
If these are too long then I have some shorter shocks.
Let me know.
Do you have some at 80mm 😀
Do you mean 80mm overall length ?
Shock length can be altered with different piston rods.
I think these shock bodies are the longest ones Tamiya made of this type.
Hi there @Cephas
@Tamiyabigstuff is right, they are the longer (and longest) rear CVAs for the Bigwig / Boomerang, which I suspect you already have on your Boomerang
For the four-shock Bigwig-style conversion you need the shorter front Bigwig damper parts, the damper body is c55mm long and creates a c90mm shock eye-to-eye
These are the dampers off my Bigwig, for the sake of comparison
I realised after thinking about it that I could just change the piston length. Do you have any with the shorter body?
otherwise I will gladly have anything, I can make them work one way or another.
very grateful for any assistance, how much would you like for them 😀
