Nwc100 462 Posted September 27, 2020 As simple as the title suggests, I've read a few different thoughts on trimming first or painting first, as a relative novice I was wondering what the best/ easiest option is? Any thoughts and advice more than welcome, it's for the street sleeping Yaris we will be doing similar to this and has lots of stick on and screw on attachments so bearing that in mind as well! We are going for this look! Thanks Nick Share this post Link to post Share on other sites
Superluminal 3750 Posted September 27, 2020 I trim first and paint later as im a bit ham fisted with the scissors and knife and would probably end up scratching the paint. I also find it easier to make tweaks to the way the body sits on the chassis posts if its not painted as you can see where the wheel arches are lining up with the wheels and if anyghing needs small amounts shaving off. 4 Share this post Link to post Share on other sites
toyolien 4680 Posted September 27, 2020 Same as above. I always trim first to get the body perfectly fitted to the chassis. Then paint. When was young I remember painting a Cougar 2000 body before cutting it. The proceeded to scratch it up with my scissors. Lesson learnt. 1 Share this post Link to post Share on other sites
futureworks 864 Posted September 27, 2020 Ditto, the convention has always been trim first, then paint. Anecdotally, Tamiya sell a Tyrell P34 6 wheeler F1 car, with pre-painted body parts, which then have to be trimmed to construct the whole body. I’ve heard that the simple act of trimming can cause paint to come away, as if it is brittle, leaving a complicated touch up job which makes a quality finish hard to achieve. edit: just found the thread about the Tyrrell - Share this post Link to post Share on other sites
c64orinoco 667 Posted September 27, 2020 Trim first, then paint. The secret to trimming is to take it very slowly. I score a faint line with a good sharp blade, then go over it a few times, then bend and snap. I use scissors for really tight areas that are tricky with a blade. Share this post Link to post Share on other sites
Fuijo 880 Posted September 27, 2020 I've done it both ways, and continue to do so. I have no real preference for either and am happy with both. Share this post Link to post Share on other sites
Gazzalene 171 Posted September 27, 2020 I have started painting first then trim. I sometimes lift the protective film when cutting so overspray can get on the out side of shell. If I mess up the trimming does not matter if its before or after, would have to use the shell anyway Just my opinion and way. Share this post Link to post Share on other sites
Howards 456 Posted September 27, 2020 Either. I find if you trim first you can fixate on things that - once painted - are not perceptible. if it’s a really complicated shape then I’d lean towards trimming first, say an older buggy shell. Later buggy shells and touring shells not so much. Share this post Link to post Share on other sites
DayRider 311 Posted September 27, 2020 I have always trimmed first, lined up the body to the chassis them drilled the post holes and hole for other body parts, i.e. mirrors wings etc. I use to use blades but then I got my self a Dremel and never looked back. These two tools are purfect for the strate bits and wheel arches. They have come down in price and if you have a good look round you can get great deals. No more bad cuts! 3 Share this post Link to post Share on other sites
rwordenjr 1890 Posted September 27, 2020 Trim first! That’s the way it should be done. 1 Share this post Link to post Share on other sites
Luftstalag13 19 Posted September 27, 2020 It depends. I think for most bodies you will trim it first and then paint it, but for some bodies, especially those with paint-like decals to apply to the edge of the wheel arches such as the BMW M3 E30 Schnitzer, you should paint and even apply some of the decals first before cutting out the body and trimming. 1 Share this post Link to post Share on other sites
Truck Norris 2237 Posted September 27, 2020 If you need to ask, then the answer is cut first. This is what the instructions state and it's in Tamiya's interest for you to get good results and be happy with your purchase. Once you've got a few under your belt you can then decide based on your experience whether it's worth the risk destroying a paint job by cutting after. I've done 50+ bodies now and I always cut first. The only advantage I can see with cutting after is cleaner edges, which you can tidy anyhow with Tamiya's Polycarbonate Body Cleaner Share this post Link to post Share on other sites
Howards 456 Posted September 28, 2020 10 hours ago, Truck Norris said: The only advantage I can see with cutting after is cleaner edges, which you can tidy anyhow with Tamiya's Polycarbonate Body Cleaner Easier to manipulate and a ready source of test material for airbrush work if the flashing is still on. obvs irrelevant if you are only using spray cans. Share this post Link to post Share on other sites
