salvine 125 Posted September 29, 2020 Anybody got tips for dying chassis parts? Been at it for a couple days with poor results. Not sure what type of plastic it is but the knuckles and J parts for TA03/02's just are not absorbing the Dye. Using RIT if that matters. Share this post Link to post Share on other sites
ACCEL 2014 Posted September 29, 2020 when my parts die i have an extraordinary place i bury them. Yes certain plastics just refuse to dye, some companies make certain parts to be dyed. post some pics so we can see the intensity of the colors, you may have to lower or raise PH levels, or it's that type of plastic and it will not matter what you do to make it so called deeper. Share this post Link to post Share on other sites
jlcox7 16 Posted September 29, 2020 Nylon accepts Rit dye very well , but alot of these parts are ABS - and dye will not take normally. I have seen some people use Acetone with the rit dye/water mix, but the results are still not stellar Look up some videos on DYing ABS plastic and judge for yourself - I always use a piece of the spare plastic holding the parts together in the kit to see If they parts will dye or not. Sometimes, we just have to accept paint if possible. Good luck! 1 Share this post Link to post Share on other sites
salvine 125 Posted September 30, 2020 I guess these parts are ABS. Tried to take some of the shine off and make the surface able to accept dye by a soak in lacquer thinner. I tried a sample in MEK but that was too hot. Share this post Link to post Share on other sites
isomer1 175 Posted September 30, 2020 (edited) @salvine what color are you going for? I can't tell which sprue is J, seems to differ on the various TA-02 variants. But the red parts are available as blue and dark silver. https://tamiyabase.com/chassis/55-ta02#all-ta02-variants Edited September 30, 2020 by isomer1 adding hyperlink Share this post Link to post Share on other sites
salvine 125 Posted September 30, 2020 11 hours ago, isomer1 said: @salvine what color are you going for? I can't tell which sprue is J, seems to differ on the various TA-02 variants. But the red parts are available as blue and dark silver. https://tamiyabase.com/chassis/55-ta02#all-ta02-variants Black. J parts usually refers to the specific parts that came with the TA02/03 FRP chassis sets. TA03 parts are very hard to come by as most have suffered cracking or damage and Tamiya has yet to re re-release them as they did for the 02 Share this post Link to post Share on other sites
Collin 1956 Posted September 30, 2020 JUST ONE! tip I can give you all. Whenever you use dying powder, mix it up with warm water outside your flat or in a room where you can mess around and use a masc or hold your breath on while pouring the powder into the water. In my kitchen, you have a lot of tiny black dots on some surfaces even some meter away from the oven where I did the dying process. This pigments can be a big, big mess. 1 Share this post Link to post Share on other sites
salvine 125 Posted September 30, 2020 I have found a few videos for ABS and harder plastics. One guy did yo-yos. I'll report back. Looks like he mixed Acetone with water 2:1 I'll try on some scrap and see how it goes. 1 Share this post Link to post Share on other sites
salvine 125 Posted October 2, 2020 Not sure what this plastic is made of but wow. Put it in straight acetone with the dye. No water added and still hardly any change in color. Parts get slightly soft meaning you can scrape the surface with a sharp object but certainly not dissolving like when my dad dropped a screwdriver in a bucket of the stuff as a kid. Tried straight MEK too with little effect. Share this post Link to post Share on other sites
Collin 1956 Posted October 2, 2020 ABS gets soft by Aceton. Usually nylon parts are used to dye. I would not put my ABS parts into an aceton bath, unlike I want to make 3D prints slick but then its only the steam of the aceton and not the liquit itself. Share this post Link to post Share on other sites
