Looking at the Blazer;
Wheelbase is 2705mm on the '82 1:1, on the kit it's 287mm so that's 1/9.4
Width is 2007mm v 240mm so 1/8.4
Hilux (1:1 used Regular Cab, Short Bed as ref)
2616mm v 287mm wheelbase so 1/9.1
1621mm v 230mm wide so 1/7
I guess it depends which dimension you're taking as the scale basis. If you look at all the 257mm wheelbase 1/10 touring cars, none of them are truly 1/10 in all three dimensions as far as I'm aware
  • Thanks 2
Nice data points!
Om paper those seem closer to 1/8th than 1/10th.
I'm being less scientific and eye-balling it. Here's a Blazer and an SRB for wheelbase:-
... and overall perception of size/scale:-
Not just the old ones:-
The original beetle has a 2400mm wheelbase (according to Wikipedia) so it's only 300mm shorter than a Blazer :o - I thought they'd have been further apart than that
With the Sand Scorcher's WB being 250mm, that makes it 1/9.6 if the wheelbase wasn't altered on Baja Bugs.  Wheelbase-wise, at least, it's almost perfect scale with the Blazer (1/9.4 v 1/9.6) - Do they use the same driver head?
They don't usually shorten baja bugs at the chassis like they do with beach buggies,.... however, they do cut the front and the back off which makes it shorter than a standard beetle..
Quote
Really interesting. So, as you say, both pretty much on scale actually. I guess the 4x4s were just much bigger vehicles (and maybe the scale effect amplifies this visually in some way).
Quote
No - the 4x4 driver figures are significantly bigger.
