Re-Bugged 10152 Posted October 4, 2020 Wow, now that is an amazing piece of work. 1 Share this post Link to post Share on other sites
Mad Ax 9325 Posted October 4, 2020 I love that the world needs more monster trucks 1 Share this post Link to post Share on other sites
Yawstring 25 Posted October 4, 2020 16 hours ago, Re-Bugged said: Wow, now that is an amazing piece of work. Thanks! I appreciate it! 1 Share this post Link to post Share on other sites
Yawstring 25 Posted October 4, 2020 9 hours ago, Mad Ax said: I love that the world needs more monster trucks Thanks! I love Tamiya Monster trucks... I hope they keep making great kits to build from. Share this post Link to post Share on other sites
MadInventor 3884 Posted October 4, 2020 Very, very nice. What are the wheels, and can you fit stock Clod tires on them ? 1 Share this post Link to post Share on other sites
Yawstring 25 Posted October 5, 2020 1 hour ago, MadInventor said: Very, very nice. What are the wheels, and can you fit stock Clod tires on them ? Hi, they are J Concepts Tribute 2.6x3.6 Monster Truck Wheels w/ adaptors they will fit clod tires. https://www.jconcepts.net/shop/tribute-26-x-36-monster-truck-wheel 1 Share this post Link to post Share on other sites
Rb4276 803 Posted October 5, 2020 2 hours ago, Yawstring said: Hi, they are J Concepts Tribute 2.6x3.6 Monster Truck Wheels w/ adaptors they will fit clod tires. https://www.jconcepts.net/shop/tribute-26-x-36-monster-truck-wheel Can you use the stock hex from txt 2 to mount the rims Share this post Link to post Share on other sites
Yawstring 25 Posted October 7, 2020 On 10/4/2020 at 11:16 PM, Rb4276 said: Can you use the stock hex from txt 2 to mount the rims Yes. The wheels come with 3 different adaptor options so you can adjust the offset as needed. The adaptors fit directly over the stock hex, but If you use the narrow offset adaptors you will have to make a spacer and place it between the nut and wheel because the narrow adaptor allows more of the shaft to protrude and you will simply run out of threads before the nut can be fully tightened against the wheel. Let me know if that makes sense or not. Share this post Link to post Share on other sites
Rb4276 803 Posted October 7, 2020 7 hours ago, Yawstring said: Yes. The wheels come with 3 different adaptor options so you can adjust the offset as needed. The adaptors fit directly over the stock hex, but If you use the narrow offset adaptors you will have to make a spacer and place it between the nut and wheel because the narrow adaptor allows more of the shaft to protrude and you will simply run out of threads before the nut can be fully tightened against the wheel. Let me know if that makes sense or not. Did you have to use a spacer? If so what did you use? Shims? Share this post Link to post Share on other sites
Yawstring 25 Posted October 11, 2020 On 10/7/2020 at 7:01 AM, Rb4276 said: Did you have to use a spacer? If so what did you use? Shims? Hi, I'll try and take some pictures and explain it better soon... Share this post Link to post Share on other sites
Mcgeo99 1 Posted October 25, 2020 That truck is AWESOME.... nice job.... I'd like to know what you did (if anything) with the axles.. Also, what mod did you do to fit those rims & tires... I'd like to do that on my Agrios Share this post Link to post Share on other sites
vodka 35 Posted November 2, 2020 Nice work! What changes have you made to the chassis? I see 2 servos with custom mount, maybe custom wheelbase, but I can't see the propeller joint. Share this post Link to post Share on other sites
