merlinh 1 Posted October 21, 2020 i have the SCHNITZER BMW M3 SPORT EVO on the ta01 chassis before the moved to the tt01 and i was wondering if tt01 part would work for hop up Share this post Link to post Share on other sites
Mad Ax 9313 Posted October 21, 2020 Welcome to TC Which hop-up parts were you considering? Shock absorbers are 55mm on both cars and the fitment is the same, so shocks for TT01 will fit on the TA01. Standard electronic stuff like motor, ESC and servos will fit as these aren't car-specific. Otherwise, you'll find pretty much everything is different and I doubt any parts would be interchangeable without significant modification. Hop-up parts for the TA01 can still be found, depending on what you want to do. Basic 'essential' mods are bearings (rcbearings.co.uk do a TA01 bearing kit) and a steel pinion. IIRC most TAs came with oil-filled shocks but if it's an early car they may be past their best. If yours are leaking or not moving smoothly, Tamiya's CVA shocks (part number 53619) are a direct replacement. You might be able to rebuild your shocks with fresh oil and new rubber o-rings. Share this post Link to post Share on other sites
merlinh 1 Posted October 21, 2020 the diffs and replacing the coat hanger of a drive shaft i have hobby king shock absorbers Share this post Link to post Share on other sites
Mad Ax 9313 Posted October 21, 2020 TT01 diffs won't work - the transmission is completely different. However TA01 diffs are still available, both original and aftermarket. I think most TAs has a ball diff in the rear and an open gear diff in the front. For easier reliability you can run a gear diff in both ends, and add some putty if you want a limited slip effect. That said the regular ball diff is reliable enough if assembled and adjusted properly. It looks like you already have a hopup propshaft installed - I may be wrong but I thought all standard props had a rounded hook type end. If itn's not a hopup it could be an early one? Anyway, there are various aftermarket options for these too. Jazrider for example make an aluminium propshaft. The DF01 (buggy chassis) uses the same transmission, so diffs, gear parts and propshafts are interchangeable. An aluminium motor mount is also a good buy for a TA01 - the plastic mount can crack if you're running over rough terrain. Share this post Link to post Share on other sites
merlinh 1 Posted October 21, 2020 i have the aluminium motor mount. do you know if anyone makes metal gears for the diffs Share this post Link to post Share on other sites
svenb 3778 Posted October 21, 2020 3 hours ago, merlinh said: i have the aluminium motor mount. do you know if anyone makes metal gears for the diffs Metal gears fitted as standard Share this post Link to post Share on other sites
merlinh 1 Posted October 21, 2020 isn't the spur gear is plastic Share this post Link to post Share on other sites
svenb 3778 Posted October 21, 2020 (edited) Gear diffs metal,spur and counter gears plastic, except for the idle(!) gear which is aluminium. The plastic spur gears are better in plastic 👍 change the idle gear to plastic too as the aluminium wears and mixers with the grease to create a abrasive paste wearing the spur gear. TA02 changed to all plastic and there's a speed tuned gear set that's worth getting. Can't remember the part number 🙄 Swap the pinion to steel as well Edited October 21, 2020 by svenb Share this post Link to post Share on other sites
merlinh 1 Posted October 21, 2020 ok thank you. do you know if the ta02 gears will work Share this post Link to post Share on other sites
svenb 3778 Posted October 21, 2020 14 minutes ago, merlinh said: ok thank you. do you know if the ta02 gears will work Yes👍 53127 speed tuned gear set Share this post Link to post Share on other sites
Wez-li 1790 Posted October 28, 2020 On 10/21/2020 at 9:13 AM, merlinh said: the diffs and replacing the coat hanger of a drive shaft i have hobby king shock absorber Interesting custom chassis there. Share this post Link to post Share on other sites
Mad Ax 9313 Posted October 29, 2020 18 hours ago, Wez-li said: Interesting custom chassis there. I believe that is an early HPI, from back in the days when HPI made hop-ups. I have one on my Top Force Evo. It appears to be identical to the one above. The friend who sold it to me said it was what Jamie Booth used in the early Top Force days - I meant to find Mr. Booth at the Revival this year and ask him about it but, well, I didn't Share this post Link to post Share on other sites
merlinh 1 Posted October 31, 2020 On 10/29/2020 at 12:04 PM, Mad Ax said: I believe that is an early HPI, from back in the days when HPI made hop-ups. I have one on my Top Force Evo. It appears to be identical to the one above. The friend who sold it to me said it was what Jamie Booth used in the early Top Force days - I meant to find Mr. Booth at the Revival this year and ask him about it but, well, I didn't I have no idea about the the chassis i got the car from a family friend. i only put the electronics in it Share this post Link to post Share on other sites
merlinh 1 Posted October 31, 2020 ok next question will ta02 parts work i know the use the same gear cases but that is about it Share this post Link to post Share on other sites
Mad Ax 9313 Posted October 31, 2020 It depends on what TA02 parts you're thinking about. Gear cases and gear internals are the same, as you can use those. Suspension arms are different, so if you put TA02 arms on you will change your wheelbase. This showroom entry shows a comparison between the various TA01/02 variants: https://www.tamiyaclub.com/showroom_model.asp?cid=48983&id=2193 Share this post Link to post Share on other sites
merlinh 1 Posted November 4, 2020 thank you. I was eyeing up a full aluminum drive shaft by yeah racing Share this post Link to post Share on other sites
