Did the Classic failure not tightening the pinion gear good enough, so car is just whining now :).
Question, just what to i have to unsdsrew to access it?, does not seem like a easy access at my first glance but hope it is (google this did not help).
Just the 2 screws into the motor mount then that should come out with the motor.
If the pinion isnt loose you may have the motor mount around the wrong way, spin it 180deg and reinstall it. I have done that before, it firs both ways but needs to be the right way to mesh properly
Thank you, it was just loose. Very easy access :)
