shenlonco 1156 Posted October 26, 2020 Things moving good with this cheap wltoys motor.. motors linked in my video description if you want to try one. 5 Share this post Link to post Share on other sites
KEV THE REV 2319 Posted October 26, 2020 Roosters galore - love it !! 1 Share this post Link to post Share on other sites
shenlonco 1156 Posted October 26, 2020 16 minutes ago, KEV THE REV said: Roosters galore - love it !! Thanks it was sure fun ripping through the sand! Share this post Link to post Share on other sites
Dakratfink 967 Posted October 26, 2020 I was going to ask this in it’s own thread, but I think this is relevant here. I am thinking of taking the Motor spaced out of my MP and running a 18T Hornet pinion . Are Hornet / Pumpkin gears standard 32p gears? Will any off the shelf 18T from my LHS work of will I need to order a proprietary Tamiya pinion ? Share this post Link to post Share on other sites
shenlonco 1156 Posted October 26, 2020 36 minutes ago, Dakratfink said: I was going to ask this in it’s own thread, but I think this is relevant here. I am thinking of taking the Motor spaced out of my MP and running a 18T Hornet pinion . Are Hornet / Pumpkin gears standard 32p gears? Will any off the shelf 18T from my LHS work of will I need to order a proprietary Tamiya pinion ? Hi I would not do that the motor will run hot and maybe burn up the tires are big on the MP why they use a smaller pinion gear. Share this post Link to post Share on other sites
Dakratfink 967 Posted October 26, 2020 28 minutes ago, shenlonco said: Hi I would not do that the motor will run hot and maybe burn up the tires are big on the MP why they use a smaller pinion gear. I was thinking of doing it with the Traxxas XL5/ 12T 550 combo... I think that motor should have the torque to run the big hornet pinion .i wouldn’t try 18aT on a silver can Share this post Link to post Share on other sites
shenlonco 1156 Posted October 27, 2020 2 hours ago, Dakratfink said: I was thinking of doing it with the Traxxas XL5/ 12T 550 combo... I think that motor should have the torque to run the big hornet pinion .i wouldn’t try 18aT on a silver can Those motors are known for running hot and blowing up easy and with a 18t pinion with the big tires I don't think it will do good.. why not buy a cheap brushless combo for like 40 bucks and stick with the stock setup? Share this post Link to post Share on other sites
Dakratfink 967 Posted October 27, 2020 Just now, shenlonco said: Those motors are known for running hot and blowing up easy and with a 18t pinion with the big tires I don't think it will do good.. why not buy a cheap brushless combo for like 40 bucks and stick with the stock setup? I’ve actually got a cheap brushless setup in it now( GoolRC 60A 3500kv combo ) It is silly powerful, but a little Twitchy with the low speed cogging. I was considering swapping that cheap brushless setup into a stampede I’ve got and trying the Titan 550 in the MP. The more I think about it, I will Probably keep the brushless setup where it is. Share this post Link to post Share on other sites
shenlonco 1156 Posted October 27, 2020 58 minutes ago, Dakratfink said: I’ve actually got a cheap brushless setup in it now( GoolRC 60A 3500kv combo ) It is silly powerful, but a little Twitchy with the low speed cogging. I was considering swapping that cheap brushless setup into a stampede I’ve got and trying the Titan 550 in the MP. The more I think about it, I will Probably keep the brushless setup where it is. Hi the reason a brushless motor coggs is from being over geared, not a good enough battery to supply it with the amps it is drawing, or the motor was overheated and the magnets are weakened or it could be to small of a motor? What size is it does the motor have a finned can because those are 380 sized rotors in a 540 size can they have way less torque, You need the true 540 size can ones without those finned cans. Share this post Link to post Share on other sites
