Back in April I felt like painting a ScorcherĀ body. With stocks dwindling at the time this one eventually turned up in September I think it was. I was planning on doing a Box Art but by the time it arrived I’d had a rethink.
It all starts with getting rid of the mould lines....
Then the paint choice...
C1A491BD-E0BD-435E-944E-AB3DD42AB3AE.md.
OnceĀ the White was applied with what I was envisioning meant that the 506 needed to be stuck on before any more painting. A bit of masking tape to help get things lined up the same both sides...
Then from some templates I cut masking the Blue Mountain could begin. You can’t go past Tamiya’s own tape for curves...
And with 10 miles of tape later Ā some paint was laid on...
Ā
Very happy so far.
I found some rear lights I’d paintedĀ on another body before realising they aren’t used so thought I’d go the whole hog and use them on this one...
The chrome part is left over from a Static truck kit super glued in and with a small pilot hole be able to have a screw in it...
My wife saw the body as it is today liking it a lot, and when I told her I’ve still got Blue to addĀ I got one of those ā€œOh....ā€ you knowĀ the one, doesn’t want to burst the bubble or anything but kind of ā€˜are you sure’ type ā€˜Oh’
She did point out that it looked very classic as it is. But I’dĀ like to still add the blue or else I’ll always be wondering ā€˜What If??’
Still I can always do another down the track without the blue if it is indeed better.
Hopefully not long before I can get this gets finished šŸ˜‰
I now have 4 SRB bodies but only 1 SRB chassis. So it could be a Dear Santa or something to get hold of another chassis so it can at least sit along side a Buggy Champ.Ā
  • Like 25
It looks great so far and if you had told us now it's finished, I'm sure most of us would like it. But I would also like to see the blue colour on it.Ā
If you are planning to add a light kit to it in the future you should paint the back of the light housing black now. Otherwise the light body will glow red.
I'm sure it'll look great with the blue added in. Don't listen to your wife.Ā
Ā
Ok, that sounded wrong.
Ā
LISTEN to your wife in general (happy wife --> happy life), but don't listen to your wife in this particular instance regarding the color of your sand scorcher bodyĀ :D
  • Haha 4
Ā
Ā
Nice saveĀ :lol:
Thanks for the tip with the black on the lights šŸ‘šŸ» Ā I didn’t have plans for lights at this stage, but you never know?
It was your enquiry on the rear lights recently that prompted me in the first place about the time found these lenses tidying up a bit.
Ā
16 hours ago, J@mes said:
Good skills! Looking forward to seeing it progress... on to a chassisĀ :P
I’dĀ like to see it on its own chassis to sometime but it will just have to share with the others for now. I wouldn’t mind a Scorcher Kit, as I’ve got another paint scheme in mind and would love a framed Scorcher box to hang on the wall with the Buggy Champ.
I’m really starting to enjoy the painting stage now and just concentrating it without the distraction of the chassis is a bonus, (well apart from the 1/14 Truck going on in the background šŸ˜†)
I’m keen to add the blue as well more for the challenge and to see if I can. Having also discovered with this one why I was getting so much orange peel on other shells is I’ve been passing with the can to quickly to avoid runs, now I pass the can by slower the end result is much better. Plus using a Tamiya nozzle on the Auto paint cans helps too.
StillĀ a fine line between a good coat and getting runs in it.
Ā
Ā
Ā
Mrs RB has asked if you wouldn’t mind just PM’ing your Phone number pleaseĀ so she can have ā€˜chat’ if that’s OK??
Just kidding what happens on TC stays on TC. But seriously if you do get a call in the middle of the night probably best just to ignore it..
Ā
5 hours ago, Badcrumble said:
I have to say it looks sharp! Such clean lines! Looking forward to seeing how this turns out.
Cheers, I did had a couple of jaggedy edges even though I’d knifed the tape before removal,Ā Ā but found that rolling a bit 1500 grit up like a cigarette and gently rubbing the edges cleaned them up nicely.Ā
Ā
See it would appear unanimous then, the other blue will be added when I get to itšŸ‘šŸ»
Ā
Thanks all for the kind words and thoughtsĀ much appreciated.Ā
Tail light lens's look just like 1:1 Fannytastic,Ā
Nice VW looks,Ā do you keep your keys up in your visor? may have to come sneak a ride:D
i wonder why Tamiya PS colors don't come in more flavors as the TS or any brand for that matter, Hmm?
Nope, I keep the keys in Glovebox so you can’t find them..........whoops........
Bluudy fantastic!! The Masking looked Pro. Those who Paint know... Prep and Masking is 90% of a Paint Job!Ā
I agree - the Blue will absolutely make it pop. šŸ‘Œ
Got the Wheels dressed up and done, I gave them a Yellow accent around the rimĀ this time.
I’m thinking they should work Ok šŸ‘šŸ»Ā
  • Like 10
3 hours of masking later...
Lay some paint on.....
Then peel it all off again. Just a couple of little spots to clean up but overall came out not to bad at all. Mrs RB even remarked on the blue looking better than she thought it would 😁.
Ā
Ā
  • Like 30
2 hours ago, ploots said:
Looking very nice šŸ‘ I'll send you my sandscorcher body for you to paint for me 😁
Cheers šŸ», after this one I could do yours in either all White or all Ā Matt Black, thems your options šŸ¤£šŸ˜‚.Ā
  • Haha 3
too generous by halfĀ :D
Ā
Looks absolutely gorgeous though mate - beautiful!Ā
Thanks bud, that’s high praise indeed from someone of your your celebrity status, I’ve still got a long way to go before I get to those dizzy heights of stardom šŸ˜‰
I was looking to challenge myself a bit with this one, it’s a relief all the tricky stuffs out the way, it should be all down hill from here 😃
    • IXLR8  »  Clappy75
      Hi Jon,
      In the linked image, I've simply moved the bar forward until it is centered directly over the rear shock tower (approx. 10.72mm) and kept the same height. Ā Is this what you had in mind?
      https://flic.kr/p/2roEkj2
      DougĀ
      Ā
      Ā
      · 0 replies
    • WhteRbt
      Checking out this status thing…  And now with a beautiful avatar! šŸ˜‚
      · 0 replies
      · 0 replies
      Hello
      Hope you are well
      Thank you for your help
      Kind regards
      Jack
      · 0 replies
    • seoondaddy
      Seo-onDaddy - YouTube
      · 0 replies
