The plastic parts to put the snap pin to hold the Lexan Body in is way to high, the Agrius manual does not have a name for the parts but it is 4 of them and are marked with F1.
I am sure i saw a special cutter for those somwhere but i first want to know if there are other ways to cut them?, i have a very fine saw for metal but i am sure that will not be a clean cut.
If you mean the body posts, you want to get a small pipe cutter off ebay for peanuts (think mine was about two quid posted)
There are other ways and you can try them but none of them cut anywhere as neatly. So id just get the pipe cuttter and have uniformly neatly cut body posts (not the chewed up random length ones I used to have before i got the pipe cutter)
Yes, i just found out that they are caled body post, with that information many things popped up. Thank you for helping i will check it out ..
Found one cheap on Ebay that should do the job sent from England so i dont have to wait for shipping from China.
I would probably find one at s harrdware store in Norway but i bet the price would be way higher.
New question. Do you think a can use a pencil sharpner on the Body post to make a bit rounder Finish?.
